delete Google account?
Usually, I've found that you either need to add another Google account in order to delete the single account. It won't let you delete the only account for some reason.
The other solution, if you are getting rid of the device, is to flash a fresh ROM installation, and just don't add your account...making it just like a new device (for someone else to have a clean slate).Randy
you can not delete it if you add your google account after you set up your tv box.Coolicool - Located in China and a trusted seller on Freaktab. We are selling loads of Android TV Sticks, Tablets, Smartphones and consuming electronic merchandises to all over the world. We have local Warehouse in Europe that our customers can get what they want in 72 hours(2-5 Days Delivery&No tariff).
Lowest Price Guarantee
Easter Special Offer!
Link: http://bit.ly/2Iy2Av4
I know for a fact it is possible on some. My Imito QX1 running 4.2.2 as one example. You must go all of the way into the account sync settings... select menu and Remove Account is an available option.
If you are on an earlier version of Android without the option and you are rooted... deleting the accounts.db located in either...
/data/system
or
/data/system/users/0/
Will also remove the accounts etc upon next reboot.
There are currently 1177 users online. 2 members and 1175 guests.
