force close on superuser
has it upgraded i had to uninstall the upgrade the other day settings apps remove upgrades on super user as mine has run an auto update so i lost all access to apps that required su as it keept fcing removing the upgrade and stoppinv auto upgrade on it worked for me
hope this helps
rickyRicky
New here but learning something new everyday
As you see on all my ROMs I have been using an older Superuser.apk. The reason is this older one fits the screen properly for a tablet and seems to be more compatible. When you upgrade you get a squeezed up UI like a phone. Also if you upgrade you need the newer version of SU to go with it. You will have to manually copy the SU binary to /system/bin and replace the one that is there.
To tell you the truth it's not upgraded because theres a upgrade available but it force closes at any attempt to use for whatever reason. Unless its the upgraded version that bob uses I'm not sure thanks for your response I'm stumped. It's version 3.0.7 if that helps any thanks cybertwigg
freaktab art developerif you like my work please buy me a pepsi
mine is v2.3.6.3 i guess that is from bobs apk if you go to settings and open your app manager find superuser and see if it says unistall click it and it should say this will uninstall all upgrades do you wish to continue then it will take you back to stock app (bobs version) just dont uninstall if it says this will unistall the app lolRicky
There are currently 2290 users online. 2 members and 2288 guests.
