Yfg1113 questions
    Swap out that set of animations so I will know if it bricks or not
    Sent from the Big Ten Inch
      good luck
        Looks like what I found is what Shaun has already pointed out in another thread. I was so excited to be rid of those green screens too.
          i couldent find those on mine must b in different locarion
            Re: Yfg1113 questions
            I just modified the 3 PNG files but it didn't load them at boot. There is something else I'm missing. Maybe Shaun knows how to change these.
              I tried for 3 hours trying to make this work. The nothing works. Is there an Mb limit of bootanimation.zip?
              Monkey Fist Rage
                Monkey Fist Rage
                go to xda site and do some digging u might find ur answer ther
                  That's where Shaun sent me and those are the things I tried for 3 hours. I will mess with it again tomorrow
                  Monkey Fist Rage
                    I had to give up on my Ubuntu machine and switch over to Windows and winrar. Did something in about 30 seconds and shoved it onto my tab. Worked beautifully.
                    Not spectacular or anything but a good first step.
                      what u do?
                        Not sure just yet. I know I got rid of the three animations and used one. I strongly suspect that it can't handle over 500kb. I was at 1.8mb before
                          cool
                            Monkey Fist Rage
                              Monkey Fist Rage
                              cool
                                Something in my tab is forcing it to sit down after about five minutes of idle time. Does anyone have any idea where to start looking to change this?
                                Monkey Fist Rage
