Custom screen resolutions for non-HD displays
I bought an Android Mini PC specifically to use on a 19" monitor that supports a max resolution of 1280x1024. I haven't been able to figure out how to set that as the resolution instead of the default 1080p my device supports. My particular Android stick is the Dell Wyse Cloud Connect (CS1A13). Is this just a limitation of the Dell? I have managed to root the device and tried an app called Resolution Changer Pro, but that doesn't work. Do I need a custom ROM? Is there some build.prop property I can set? Any help is greatly appreciated. If someone has a device that works out of the box like this, I'd love to know what make and model I can buy to gain this functionality. The only thing I want to use it for is Remote Desktop to my home computer using Microsoft RDP.Tags: None
Hey man, sorry but i got nothing axcept a googling for you on the resolution issue. --> http://android.stackexchange.com/que...-rooted-device
although if this does not help you perhaps you can help me?
I have the same dell-stick as you and looking into rooting it, but i have come up with nothing.
Think you can be of assistance?
Originally posted by noll8an View PostHey man, sorry but i got nothing axcept a googling for you on the resolution issue. --> http://android.stackexchange.com/que...-rooted-device
The device shipped with a native resolution of 1920x1080 (1080p). The monitor I wanted to use it on runs at 1280x1024.
Yeah i noticed the issue with Play store, lucky there is other sites that doesn't check what kind of device I'm using
Do you mind linking to the youtube video, if you still remember it, or at least what you searched for,
it seems that i can not find anything regarding the wyse client and rooting?
Originally posted by noll8an View PostYeah i noticed the issue with Play store, lucky there is other sites that doesn't check what kind of device I'm using
There are currently 2847 users online. 1 members and 2846 guests.
