USB Gigabit lan adapter
I dont think it will allow you to have a link more then 100mbit. Ethernet has auto negotiation features to see if you have a straight or cross cables, so it also looks if it can handle and if the peer can handle 1 gig. Unfortunately there is nothing in between 1000 and 100.
Might end up hurting the other devices in the USB Hub btw.
.11ac supports channel bonding, that is what i reckon the only benefit you can get from it.
Minix has a single antenna, so it cannot do more then one stream. a single channel in 11ac is 20mhz, you can combine up to 40mhz, 80mhz or even 80 + 80mhz so it should be able to get speeds up to 480mbit, but that is Half-Duplex and still cannot compete with Ethernet, especially if your AP is busy (5+ clients)
Originally posted by morfarj View PostAnyone know a 100/1000 lan adapter wich is working for these devices? I know it's only usb 2.0 so max speed is 480 mbps, but still faster than 100 mbps though.
I have LAN7500 USB2 and ASIX USB3 chipset devices running on 800MHz dual core ARM Satellite boxes.
I've compiled in support for LAN7500 devices in my KitKat kernelsMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostYou will only get 1/2 of that even! Real world USB2 throughput with a FAST CPU is about 250-260 mbps.
I've compiled in support for LAN7500 devices in my KitKat kernelsDid you test the speed of the lan7500 adapter?
Originally posted by morfarj View PostSounds good. anything faster than 100 mbps would be nice.Did you test the speed of the lan7500 adapter?
I've left LAN7500 support turned on so all my builds in the last week or so have support.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 2377 users online. 1 members and 2376 guests.
