Recommendation for a good power supply for Mk808B (UK)
http://uk.rs-online.com/web/p/plug-in-power-supply/7653311/
Hi guys how about this stockist only a couple of miles away.
Ed
Originally posted by eddieaok View Posthttp://uk.rs-online.com/web/p/plug-in-power-supply/7653311/
Ed
Looks good to me, RS have always been top notch for components in the past from my experience, also the PSU you have linked to has a multitude of compliance ratings - some of the cheap Chinese suppliers will just stick anything the customer asks for on them.
I am in search For a suitable PSU as well. I have a powered USB hub. I connected my qx1 through powered USB hub which is 5V, 2.5A. All sorted no freeze. It might be an option as well. All in one. Hub and PSU
Sent from my GT-I9300 using TapatalkGet 15 GB Free Cloud Storage on Copy.
https://copy.com?r=ihG93E
Which One?
Lionsl2005I am in search For a suitable PSU as well. I have a powered USB hub. I connected my qx1 through powered USB hub which is 5V, 2.5A. All sorted no freeze. It might be an option as well. All in one. Hub and PSU
Thanks I will check this out I have came across the the following 2 PSU's on Curry's website
Any feedback and and advice would be appreciated, which one to go for.
Ed
x2 PSU Tests
Model LA 520W. Input 100-240VAC0.3A 50/60Hz Output 5V----2000 mA came with device from China
Wireless Link speed on x 3 power ups 65, 65, 52Mbps
UNTUTU Benchmark best of x2 tests
Overall 11438
Multitax 2246
Runtime 1023
CPU Integner 961
CPU Float point 699
RAM Operation 766
Ram Speed 882
Model Sandstrom Dual USB Charger SDL SUB12 2 x 2.1 Amp 5 Volts from PC World (ARGH made in China)
Overall 11568
Multitax 2159
Runtime 1039
CPU Integner 964
CPU Float point 705
RAM Operation 761
Ram Speed 890
A small improvement with the Sandstrom I am worried about the made in China though? should I go for a refund and order the RS model http://uk.rs-online.com/web/p/plug-i...upply/7653311/
or will this also be sourced in China
Ed
Its always good to get a proper branded ones.
I use one of these dual usb, also company sell on ****
http://www.****.co.uk/sch/portapow_c...p2047675.l2562
There are currently 1984 users online. 1 members and 1983 guests.
