Sent from my GT-I9300 using Tapatalk
Recommendation for a good power supply for Mk808B (UK)
This is no good . its 0.3A. You have to look for one 30000 ma.
Sent from my GT-I9300 using TapatalkGet 15 GB Free Cloud Storage on Copy.
https://copy.com?r=ihG93E
Will this PSU do the job
http://www.portablepowersupplies.co.uk/mains-car-chargers/
Thanks to kmac21 for pointing me in the direction for one of these.
Will this provide the power I need?
Ed
Originally posted by bjbumblebee View Postas explained in the header, its a 2a usb plug for ipad cheapest on the high street £7, might be a no name but asda darent for the life of em sell any old tosh....
You need to stop being cheap and just get one from maplin or somewhere, what's the point in searching online for probably a fake one and having constant crashes/reboots after you wait over a week to get it?Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
second hand store
I know I said this in a earlier post but I am going to repeat it again. I know you guys are in GB. But, I presume you have second hand stores over there too. I have no idea what you would call them over there? Im talking about a place that would sell used electronics.
Most of these places are going to have a box that they throw adapters and power supplys in to that they cant match up to something in the store.
Find the store. Find the box. Look for a 5v 3a adapter. See if you can find one with a good brand name on it. Case in point. I found a dlink adapter 5v 3a with a barrel on it. Cut and splice to usb cable. Done. Cost me two dollars us. Its simple. There are youtube vids to show you how. Its only 5 volts. Your not gona kill yourself..lol
yes re porta power plus it has two usb connections, i use one for an 802iiis with a powered hub with no problems.
This is the one I use
http://www.****.co.uk/itm/Dual-Micro...#ht_1127wt_958
this is the hub although not neccessarily from this seller, you don't need the inc power supply if using above but will probably need a longer usb printer cable than the one inc if your hub is any distance away from your dongle. Same goes for the micro usb cable. I have also got porta power connected to a wireless remote controlled plug to make easier to switch on and off whole system, similar to link two.
http://www.****.co.uk/itm/EU-AU-Stan...ht_5917wt_1041
http://www.****.co.uk/itm/Master-Plu...1#ht_120wt_958
also need a usb to barrel cable to replace hub power supply
http://www.****.com/itm/2X-5V-DC-Pow...E:L:OC:GB:3160Last edited by kmac21; 05 March 2014, 04:45.
Originally posted by kmac21 View Postyes re porta power plus it has two usb connections, i use one for an 802iiis with a powered hub with no problems.
Ed
Problem Sorted
Update
My PSU has arrived http://www.portablepowersupplies.co....mains-charger/
My XMBC problems now seem to be sorted
Thanks guys for your help
Ed
Hi Eddi.
Are you using micro USB Y cable with this ?
I noticed portapow also sell cables would you recommend a replacement cable also?
Ed
There are currently 2216 users online. 1 members and 2215 guests.
