MK808/B_Feb 2014_Media Centre Edition_Rom
    Thanks Mo working great with 720p reflashed the kernel. No more messing with 1080p
    Ed
      youtube app
      Hi guys, i have installed this rom but for some reason youtube app plays no video, while i see the controls (play/pause etc) ans sound. But no video. Anyone have any ideas what is wrong?
      I have flashed 720p kernel and that is setup as resolution as well
        Change sys.hwc.compose_policy=0 to =6 in build.prop file, /system/build.prop
        with ES File Manager, set Root Explorer on.
          Just did that, but no change
          Edit: after a reboot it is fine! It works! thank you very much!!
            New website with Rockchip ROM's and tweaks.
              nice there. I didn't find a kitkat for mk808b (903) even no standard rom for that device.
              do you know whether it's available ? if so, where can i get it?
                I have a KitKat ROM for MK808(RK901 wifi) and one for MK808B(RK903 wifi doesn't work, bluetooth does work). Still trying to make MK808B wifi work, very close, got the system to recognise and load the wifi driver but it's still not powering on. Will do more tests later the week. Will upload the MK808 KitKat one and if I get the MK808B's wifi working also to my site.
                  Wow. Will your rom support aptx?
                  Thank you.
                    Thank you.
                    Don't think Rockchip hardware supports aptx.
                    You can still use normal bluetooth earphones/speakers though.
                      Hi Mo123.
                      Tell me something,
                      Your version of the KitKat ROM for MK808(RK901 wifi) works, or none of them works?
                      Thanks if you cold respond.
                        Originally posted by pajopasa View Post
                        Hi Mo123.
                        Tell me something,
                        The MK808(RK901) one works.
                        Just want to add some more apps, tweak it and improve it.
                        Then I have to backup and upload it.
                        After it's completely finished, will take 6-10 hrs to upload, can only do when I'm not using the PC at night.
                        Will have latest XBMC with excellent video playback for Rockchip devices.
                        Inbetween I also have to test RK903 wifi which takes a lot of time, so maybe in 2-3 days all will be finished.
                        I did release a MK808/b KitKat ROM earlier but without any working wifi.
                        KitKat starts up a lot faster on MK808B(dual-core) than on my Quad-Core Box for some reason.
                        Any features in particular you want included in the ROM?
                          Thanks for the great news about the rom
                          Well the main use for me will be for the xbmc.
                          For many people this isn't the most important, but i ask you.
                          It is possible to make the rom or a copy of the rom cleanest possible? Removing the apps and only maintain the ones that its impossible to remove for the rom to work??? but tweak it and improve it.
                            Yes, will make a basic version with very few apps.
                              If it is possible in my case i will appreciate.
                              But maintain your tweaks and improvements on it
                              By the way, the rom haves support for Ethernet?
                                Asix would be fine.
