PMP5580 rom porting to NX008HD8G_WM
Nnlynx over on the cyangenmod forums has posted cm10.1 10.2 and cm11 roms that with a little work should be compatible with out tablets. Creating this topic to discuss this and any work arounds we come up with. Ill be starting with 11 tonight as 10.1 and 2 seem to have been tested. Having a complete backup and copies of the appropriate stock roms is reccomended.Tags: None
Originally posted by Micheal View PostNnlynx over on the cyangenmod forums has posted cm10.1 10.2 and cm11 roms that with a little work should be compatible with out tablets. Creating this topic to discuss this and any work arounds we come up with. Ill be starting with 11 tonight as 10.1 and 2 seem to have been tested. Having a complete backup and copies of the appropriate stock roms is reccomended.
The PMP5580c is nearly (if not entirely) identical to the Next8HD8G-NXM8000ND_WM.
Here are my own results in my first round of testing his ports on my own NXM8000ND_WM.
CM10.1
Bootlooped. I could net get it to fully boot....
CM10.2
Booted. Screen rotation is 90 degrees off. Cyanogenmod profile app force closes infinitely. It looked like WiFi along with bluetooth dongle support may have been working, although I did not attempt to test further.
CM11
Bootlopped. I could not get it to fully boot...
Here is some good news though, I learned how to COMPLETELY fix screen rotation in my own CM10 build. (Don't ask how, I have narrowed down the exact details yet, but it is working on my build.) I only need to test and fix WiFi, storage mounts, and new features on my build, then I should be able to release it and start porting it to other models and working on newer CM versions.
ShaunMTFreaktab Rom Developer
q
Originally posted by shaunmt View PostIt should be noted that the ROMs in questions were originally created for the Ainol Elf2 and then ported to the the PMP5580c.
CM10.1
CM10.2
CM11
ShaunMT
cm-10.1-20130917-UNOFFICIAL-elf2
Copied from NX008HD8G_WM kernel and modules, init, and narcpi.ko (needed for wifi). Added init.cm.rc. Made a change in egl.cfg (commented out android). Modified init.rc, init.amlogic.rc, and ueventd.rc to better match NX008HD8G_WM configs. Antutu benchmark 11424. Anyone want to test?
Archos Gen9 A80S cm-11.0
Kindle Fire 2 cm-11.0
q
Originally posted by stevemp View PostCopied from NX008HD8G_WM kernel and modules, init, and narcpi.ko (needed for wifi). Added init.cm.rc. Made a change in egl.cfg (commented out android). Modified init.rc, init.amlogic.rc, and ueventd.rc to better match NX008HD8G_WM configs. Antutu benchmark 11424. Anyone want to test?
https://www.mediafire.com/?p4agtudglfnwhuuLast edited by roadkill; 27 February 2014, 03:12.
Originally posted by roadkill View Postjust use cwm ti install right i installed it i still have rotation ishue the 90 rotation works right not but no 180 rotation
I used the CWM from cm-10.1_for_pmp5580c_with_bt_support.zip, should test with ShaunMT CWM also.
First wipe data/factory reset--wipe cache partition. Then flash in order:
cm-10.1-20130917-UNOFFICIAL-elf2.zip
gapps-jb-20130301-amlogic.zip
Next8HD8G-cm10.1_compatibility-signed.zip
jb-mr1-usb_bluetooth.zipArchos Gen9 A80S cm-11.0
q
Originally posted by stevemp View PostDid you do a complete wipe before installing? I wiped and tested twice and it worked. Sometimes it lags when rotating, still needs more work.
Originally posted by roadkill View Posti did it again now works little slow on rotation but atleast it works
I also figured out how to fix wifi.
I think the only things left are camera and storage mounting, but I think I know what the problem with them is.
I'm going to leave it alone for now though and go back to working on stock ROMs and ubrick kits.
Originally posted by shaunmt View PostI've got rotation working on my personal CM10 build as well, if not better than it does on stock.
ShaunMT
Originally posted by roadkill View Postcan u tell me how got screen rotation working good?
Also, I don't know if the same changes would even apply to the PMP5580 ROM.
I'm using a base ROM that I personally compiled from source, using my own device tree. I'm actually even building some the hardware support files from source, instead of pulling the files from stock rom, including the rotation sensor among other things.
I'm not sure, but I think one of the reasons the PMP5580c ROMs aren't working perfectly is because they were built for the elf2. I suspect the compatibility patches were created by simply swapping some files from the stock ROM. The combination doesn't seem to solve all the issues with the porting the ROMs from the elf2 to the PMP5580c or the Next8HD8G.
Christian Troy knows Android source inside out, and it even takes him several tries to get working compatibility patches made for devices he doesn't own.
I'll take another look at my CM10 files after I get this next round of stock ROMs and unbrick kits released.
Originally posted by shaunmt View PostWell, to be honest, I need to go back over my build.prop changes to determine which combination of changes actually resolved my remaining issues and which changes had nothing to do with it.
ShaunMT
Originally posted by Sumphlet View PostShaunMT, will you be able to make CM10 for WMN devices as well or is that a very difficult task? (I don't quite understand the difference between the two)
It should also be possible to start updating to CM10.1 , 10.2, on up to 11 (KitKat)... and then start on other ROMs sources like AOKP, Paranoid Android, PACMAN, etc...
Until the quad cores come out this year... that might be a whole new challenge...
Originally posted by Micheal View PostI've got the cm11 installed and its performing pretty well. The workaround for rotation I'm using is to disable the rotation on the 0 and 90 degree sides. It keeps the tablet from rotating when I don't want it to. Will work until I find a fix.
There are currently 2793 users online. 1 members and 2792 guests.
