anyone ???? help please !?!?
NextBook 7P12 SE - Ice Cream Sandwich - Finless ROM 1.2 Root and Gplay
Reply to Q?
Originally posted by ak111 View Postanyone ???? help please !?!?
I again state follow the directions!
I hope I made myself clear and that you should follow the directions that finless gave and there should not be any problems. When you are done installing use astro and lookup the file RKUpdateService.apk and delete it and you will get rid of a little annoying popup that comes up about every 15 minutes.
oh and don't forget to follow the directions given in the readme file
Originally posted by etbrowne View PostNot for the SE but if you follow the directions it will not brick
thanks , but is it revisable if anything goes wrong ,,, i mean if it is not compatible, ie, if screen doesn’t respond to touch or something like this????
Thanks Bob for doing this! I just installed it last night on my new NEXT7P12 SE, after being disappointed that I couldn't get all the "good apps" out of the box. Downloaded the modified ROM, followed the instructions (which worked 100% perfect) and presto I was in business. Very happy with this device now.
Just flashed my YF1211 device last night, WIFI is working, Netflix works, this is very awesome, thank you for your hard work.
I've got some more things to test, including installing a WPASuplicant to see if I can get AdHoc working, but I'm really impressed and pleased with this image. Thanks!
PosiCat
Re: NextBook 7P12 SE - Ice Cream Sandwich - Finless ROM 1.2 Root and Gplay
Hey Bob, is there any way to carry over whatever fixed Netflix on this ROM to Snake killers?
RandyRandy
I do not know what the fix was. It was done by Nextbook and released in a stock ROM. It would take me a lot of digging to see if I could figure it out.
I have a Next7P with, S/N YF1211. It was stuck in a reboot loop after the battery died.
I decided to give the ICS ROM a try. It upgraded and it booted to the Nextbook setup.
The tablet touch screen isn't responding - tried a hardware reset and it just boots to the lock screen.
Only the power button seems to do anything.
Wondering if it's a ROM problem, maybe a problem the touchscreen driver or if it's a hardware issue.
What's the best way to go back to Gingerbread or or stock ROM?
There are currently 1564 users online. 0 members and 1564 guests.
