NextBook 7P12 SE - Ice Cream Sandwich - Finless ROM 1.2 Root and Gplay
rooted nextbook
Originally posted by arobro View PostI have rooted a stock nextbook with the new YF111 serial number using an update.zip method. So should be able to get the stock rom now.
whats involved in just rooting the tablet as im fine with the rom at present but would love to o/c it just a wee bit if poss
cheers
cheers
NEXTBOOK 7P12's ADB! Please Help!
Originally posted by Finless View PostOK so here you go Nextbook 7P12 SE users!
This IS NOT for the Nextbook 7P S Resisitve screen model or any other Naxtbook 7 tablet (older models). See my Resistive screen ROM for the 7P S model
This ROM is based off the successful STOCK ROM dump provided by FreakTab user Randy. It is fully rooted, /system is read and write, SU and SuperUser pre-installed. Google Play pre-installed. I have also removed the kernel from boot.img as this makes the system run and boot a little faster.
This HAS been tested by owners of the Nextbook 7P12 SE and works with no known issues.
__________________
SPECIAL THANKS to FreakTab user Randy and kibmcz for getting this ROM to me!
Does it work on all Nextbook 7P tablets? Not sure! But the fact that it does boot on my 10G2 means it is a working ROM. I cannot test anything about it on my 10G2 but again it does boot.
Anyway for those that want to try it, here is the Nextbook 7P12 SE ICS Finless ROM V1.2 download.
ROM -> Nextbook 7P12 SE ICS ROM 1.2 by Finless (200 megs)
PLEASE READ THE README.TXT inside this kit.
YOU MUST and I am serious about this MUST EraseIDB and click the loader check box in the flash tool! This has a new loader version 2.14 and you must use it! Actually I tested and Loader 2.08 (old version) works too but it is slow compared to the new version. BUT do what I say please to be sure!
Enjoy Nextbook users and let me know how it all works!
Later I will probably have a fully rooted version up with Google Play installed soon. So I am waiting to hear how this works as no sense it working on a root if it doesn't.
Originally posted by moh21 View PostHow Can I Use The ADB? I Hooked device while its off, while pressing both volume buttons and new unrecognized device appeared in Device Manager, used update unknown (USB) Device and selected Google drive's directory and unsuccessful update message appeared. Used "Have Disk " feature after selecting drivers category and loaded .INF file in same category . A list of three Drivers appeared (ADB interface .. , Composite ADB interface... , Bootloader interface... ..) I tried all three and it didn't work. killing adb server and starting again. repetition used 3 times, nothing further. I have a knowledge on system just typing in a hurry. Please help recognizing device's ADB.. ASAP.. Thanks ..
If you have root try wifi adb. (See below)
Also with your tablet plugged in, go to device manager==> click on properties for the adb driver==> details tab==> hardware ids. and then post all the values.
If they contain 0000 that means you are using one of the newer Nextbook tablets that has a modified usb host controller to stop people using adb. This can be worked around by installing wifi adb from the android market. This requires root.
Outbound audio issues with Skype?
I downloaded this ROM and it works like a champ. Thanks for your efforts. One issue I have found is that when Skype is loaded the video portion of the video call works fine but audio isn't transmitted. Inbound audio is fine it's just that they can't hear me. Is there an easy fix for this?
next7p1n graphic issues
this is very nice Bob, anyway i have next7p1n tab, after i use rom 1.2 of 7p12, i install juggernaut revenge of sovering and theres seems to be a problem on the graphics, the character and enemy is not moving, only their weapons. i use to reinstall this about five times but still theres a proble, sam thing on frontline commando but the problem is, the gold, warcash, price and specs of items on store are not showing, theres just a blank space. i hope you can help me with this. thanks a lot...
noob
just got this from big lots so if i screw it it ill just take it back and try again. im a ios jailbreaker, 1st time android user. thanks!
__________________
Later I will probably have a fully rooted version up with Google Play installed soon. So I am waiting to hear how this works as no sense it working on a root if it doesnt.
There are currently 5258 users online. 2 members and 5256 guests.
