southpole
UT2 Stock Firmware
Originally posted by flhthemi View PostMan I just ordered one of these! How well is this device working for you? I should have mine in a couple more weeks.
Asked for the firmware so I had a back up before I start to play with it....
Just pass it on...
southpole
Originally posted by Agaam50 View Post@wasser
That is very good news, for UT2 32G and 8G?
yes, i will make for both
Ugoos UT2 installable rom status
I have a few Ugoos UT2 in my possession. I've been successful in installing the following Minix X7 roms onto my UT2 8GB and they all seem to all work without a hitch as mentioned by FLUMPSTER in one of the forums.
HardwareGuru 04 rom - OKAY, remote works, WiFi works, ethernet works
justXBMC rom by lewy20041 - OKAY, remote works, WiFi works, ethernet works
Finless 1.8 - OKAY, remote works, WiFi works, ethernet works
The BEST thing about the Ugoos UT2 is that it's versatile as the great Minix X7.
Thank you all developers for these AWESOME roms!
Originally posted by mxcoinc View PostI have a few Ugoos UT2 in my possession. I've been successful in installing the following Minix X7 roms onto my UT2 8GB and they all seem to all work without a hitch as mentioned by FLUMPSTER in one of the forums.
Mxcoinc did you notice when rooted, the on button led was blue and red??? When not rooted it consent blue.
When I had it rooted with Finless 1.8 was running fine...
southpole
I like the justXBMC version and remember it was rooted and I did notice blue/red led on the power button. Hardware guru rom also rooted and show blue/red led in power button.
My boxes are at work. I have one box at home with Quickshot V2 it. Will check on it later and let you know.
Sent from my SM-N900T using Tapatalk
hi wasser
Originally posted by wasser View PostHi all,
i just want to let you know i even finished the wasser-1.2.5 firmware for UT2 and will upload it at this weekend.
wasser
There are currently 2082 users online. 1 members and 2081 guests.
