UT2 Stock Firmware
    Originally posted by zuberek View Post
    quick question, just bought one of those boxes, no labels, nothing, done stupid thing, without backing up original firmware just used wrong firmware and box died, comes back to life after I uploaded your firmware 1.2.4 and now 1.2.5, all seems working ok except Ethernet and remote control, is it means my version is UT2? Bluetooth build-in and works with 1.2.5 version, anyway thanks for your great work, really impressive
    could you please make a photo from this device so i can see?
    wasser
      wasser
      photos of unit, remote and box, thx
        This is not a UT2. Lucky you got it working at all...
          it's not ut2, it's t-r42 clone!
          wasser
            hi wasser
            wasser
            ok, thank you, just sort out remote problem, just used old pc remote controller and remaped the keys, so got working remote, just the ethernet left to sort out - if you find any solution please let me know, regards
              hi wasser
              wasser
              just took same photos of internal board...:-)
              just founded my stock firmware, link: http://www.gigasize.com/get/hjtyzhsomdf
              I really like your firmware, maybe stock will help you to get remote and ethernet drivers for my version...please help if you can...thank you
                hi wasser - problem sorted out
                I used firmware from http://www.freaktab.com/showthread.p...2-device/page5
                all working great - just had to use tun.ko installer to get vpn working.........so happy
                26.02.2014 by Frant
                1) Kernel vsync fix
                2) Added Reboot application v.1.2.1
                3) Rooted
                4) Tweaked build.prop (present original, see in /system/ )
                5) Added overclocked kernels
                6) Added loader drivers (for programming mode)
                7) Added RKDevelopTool_v1.37 from firmware Wasser 1.2.4 pack (for loading kernels)
                8) Added RKbatchTools (for loading image)
                  Hi all,
                  i just want to let you know i even finished the wasser-1.2.5 firmware for UT2 and will upload it at this weekend.
                  wasser
                  Thank you!! Where can I find it?
                    @Kingpin
                    this weekend will be Wasser upload his new version. i think saterday evening.
                    is there anyone who knows where Wasser is?
                      does this stock firmware work with the 32gb
                      also the minix firmware does it work with the 32gb version also
                      any links
                        32 gig versus 8 gig
                        Can someone please explain why the firm ware would be different if it is 32 gig or 8gig. I assume that it is only internal memory size which I assume should not affect the firm ware. Can someone please explain this to me.
                          go back to the main menu and flash the new ugoos 3d launcher .
                          i have it on my 32gb box.
                            The stock firmware 8 GB will work with 32 G unit, I have re flashed my UT2 with it and have no issues.
                            see post #56 from Geekbuying http://www.freaktab.com/showthread.p...-Reviews/page3
                              Link's Down
                              Originally posted by southpole View Post
                              Here is the latest UT2 stock firmware 2014.2.13.
                              MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
                              southpole
                              Ops,Link's down.
                              Could you please reupload it on a different server/filehosting site?
                              EDIT: False Alarm.Mega is unreachable from my country.
                                Downgrade
                                Hi guyz,
                                I was wondering how to downgrade my Ugoos ut2 from Wasser Version 1.2.5 (Jb) to stock version (http://ugoos.net/downloads) cause it's very unstable:it freeze and reboot very often (almost every 10 minutes) and without a cause (maybe too much cpu task).
                                i've tried with RkBatchTool 1.7 but i've almost bricked it.
                                I've set the ugoos to FlashMode (reset pin + switch)
                                I've started RkBatch after the pc recognised it but it failed.
                                Could someone help me?
                                Sorry my bad English!
