Unbrick Kits for Amlogic Based Nextbooks - Support Thread
    What are they:
    The kits below contain pre-made disk images to create Rescue SD Cards for the corresponding Nextbook tablets. These should only be used if you are unable to access recovery mode by other methods, for example, if your bootloader is damaged or if you've flashed an incompatible ROM.
    Unbrick kits for additional models will be added to this post in the future.
    How they work:
    A rescue SD card contains a modified bootloader embedded in it's boot sector. When an Amlogic processor boots up, it always looks a bootloader in the external SD card first. This allows your tablet to boot entirely from the SD card instead of from internal NAND memory. The files on the card then wipe your internal bootloader, boot image and recovery image, and start recovery from SD card so you can flash a new ROM.
    How to create the Rescue SD Card:
    Download the corresponding unbrick kit for your tablet. Make sure you get the right one. DO NOT attempt to use an unbrick kit for a different model. If an unbrick kit isn't available for your tablet, wait until one is. If you're not sure, ask. Someone here on the forums will be able to answer your question.
    Unzip the unbrick kit.
    Inside you will find instructions for windows or unix. Choose one and read it entirely and carefully before beginning.
    Files are named in the following format: Unbrick_Kit_"Model"_"Board".zip
    check board in ro.product.board, ro.build.product, ro.build.description or ro.build.fingerprint
    Downloads:
    Unbrick Kits for Amlogic Based Nextbooks - Download Thread
    ShaunMT
    Freaktab Rom Developer
    New Stock Based Next8HD8G ROMs Coming Soon
    FYI
    New ROMs based on stock build dates of 10-28-13 for both Next8HD8G boards will be following very soon.
    ShaunMT
      Woohoo! You da man!
      Originally posted by shaunmt View Post
      FYI
      ShaunMT
        will it boot without stockromon ext card
        Not having ant luck. but do not have a stock rom for the Next8HD8G-NXM8000NBD_WMN. Just Staying black screen :-)
        FYI
        ShaunMT
          Yes, it should boot to recovery even if you don't place a ROM file on the SD Card.
          What size SD card are using? What files are on it after creating the Rescue SD Card?
          ShaunMT
            No Luck on Rescue
            Using 8 G sd.
            the files on it are:
            aml_autoscript
            uImage_recovery
            u-boot.bin
            uImage
            I figured power + volume down would boot into cwm but no love. Just staying black. Bricked when I flashed old rom and figured boot looder was toast. originally though I did root it with the recovery 3e and kysier
            Yes, it should boot to recovery even if you don't place a ROM file on the SD Card. serial is YFG1013042441
            ShaunMT
              Using 8 G sd.
              aml_autoscript
              uImage_recovery
              u-boot.bin
              uImage
              Have you tried it more than once? Occassionaly, I've had trouble getting it to boot on the first try.
              Also continue to hold both keys until recovery appears.
                Still Trying to Unbrick
                Noticed that img file is 1.9 g and sdcard is formatted to 1 g with the 4 files on it. tried with 8 g and 64 g cards. Is that what I should see??
                  Sounds funny, but try holding volume up and then adding the power button.
                    Yes, that is normal... the remaining space consists of the bootloader in the boot sector (in front of the mounted partition.) and some unused space at the end (which I should have trimmed off to make the download faster).
                    ShaunMT
                      Couldn't hurt to try... I forgot that some models use volume+ instead of volume- to boot recovery.
                      ShaunMT
                        q
                        ShaunMT
                        on mine some times i have to use vol + some times vol- to get into cwm recovery wierd
                          Afraid it is a deep brick and dead!
                          nothing I do works time to put it away! Perhaps someone will find a trick,
                          ShaunMT
                            q
                            whats not working for u
                              No boot with rescue sd
                              made sd but still no boot. tried all possible combos of power and volume
