saw this and dug this brick out of the trash and figure I will try the new unbrick? this wmn had no led power light but now is blinking when plugged into to power supply. Is the a stockor custom rom for the wmn yet? may have missed it. ThanX for all your efforts.
Unbrick Kits for Amlogic Based Nextbooks - Support Thread
Guess I will try it before it goes into the trash again
saw this and dug this brick out of the trash and figure I will try the new unbrick? this wmn had no led power light but now is blinking when plugged into to power supply. Is the a stockor custom rom for the wmn yet? may have missed it. ThanX for all your efforts.Originally posted by shaunmt View Post
Originally posted by rbitting View Postsaw this and dug this brick out of the trash and figure I will try the new unbrick? this wmn had no led power light but now is blinking when plugged into to power supply. Is the a stockor custom rom for the wmn yet? may have missed it. ThanX for all your efforts.
ShaunMTFreaktab Rom Developer
Is there any way to tell if a tablet is WM or WMN other than checking build.prop? I only ask because there's no way for me to access that file at the moment since the tablet is bricked.
Never mind, found the recovery log (advanced>report issue), it's the WM model.
After reading some of the information in that I'm thinking that it could be either since it's information from the stock rom provided here.Nextbook NX008HD8G - Rooted
Originally posted by silver9990 View PostIs there any way to tell if a tablet is WM or WMN other than checking build.prop? I only ask because there's no way for me to access that file at the moment since the tablet is bricked.
Both of the Next8HD8G unbrick kits are fine... all of the M6 chip tablets appear to use the same bootloader. The only difference is the boot.img (uImage) and the recovery.img (uImage_recovery) and the ROM.
Is my tablet history or is there hope?
I am needing help with my Nextbook Premium NX008HD8G tablet! Serial number YFG1213022529. My problem is it was stuck in boot loop with the chick with headphones on now it will not boot at all and the light to to show if it is charging was on but now its not. I tried to use unbrick kit for WMN (thinking that was my tablet, now not so sure!) and reading how others had this problem but it tells me error for making sdcard rescue. I am using 8GB sdcard on Wndows 7 Ultimate SP1. I also tried every way plausible to turn it back on.
Really could use some help if anybody can.....
Originally posted by ATLien View PostI am needing help with my Nextbook Premium NX008HD8G tablet! Serial number YFG1213022529. My problem is it was stuck in boot loop with the chick with headphones on now it will not boot at all and the light to to show if it is charging was on but now its not. I tried to use unbrick kit for WMN (thinking that was my tablet, now not so sure!) and reading how others had this problem but it tells me error for making sdcard rescue. I am using 8GB sdcard on Wndows 7 Ultimate SP1. I also tried every way plausible to turn it back on.
You'll need the unbrick kit.
Tell us more about the error you're getting when trying to make the rescue sd card...
What are you doing before the error.
What does the error message say?
Originally posted by shaunmt View PostI saw that you tried to install the stock ROM... It only worked on NXM8000ND_WM tablets. You've probably got the NXM8000NBD_WMN model. I'll be posting a modified ROM for it today.
ShaunMT
3/25/2014 1:50:28 AM Copying...
3/25/2014 1:56:07 AM Write Error occurred at offset 1,975,451,648 (27)
3/25/2014 1:56:07 AM Cannot write to target, aborting...
3/25/2014 1:56:07 AM Average speed: 5.8 MB/s
3/25/2014 1:56:07 AM Operation terminated at offset 1,975,451,648 LBA 3,858,304
I am following the directions included in the download for windows. I have used two different sd cards, a 8GB and 2GB, both sd cards are fine and have no issues. I am curious though, I have misplaced my sd adapters so I was using through my samsung admire rooted phone in cwm..I mount sd then I mount usb storage and it never been issue before, however I haven't been trying burn images either! Could that be my problem?
I did find this on slatedroid about unbricking AmLogic related tablets. Here's the link address:
I have one other tablet to brick on me and that was an Super Pad Tablet PC by Infotmic which had charging issues from the start and during an official upgrade download it shut off while charger was plugged in on a full battery! I made a bootable sd card using Hex editor and it worked first try.
Thus my interest of rooting and tweaking any Android began...
I really feel like my problem is the adapter for rescue sd....I am holding off trying hard brick hack that I found on slatedroid to jump start it back to life until I hear back from you.
Thanks for your time and speedy response back!
This is the error I am getting:
For those who may have missed the posting... New Next8HD8G ROMs:
ShaunMT's Modified Stock Based ROMs for Amlogic Nextbooks (Download Thread)
ShaunMT's Modified Stock Based ROMs for Amlogic Nextbooks (Support Thread)Freaktab Rom Developer
Eeny meeny miny moe, catch a rom by the download....
Again thank you for your time and hard work!
Originally posted by ATLien View PostOk I am headed out to grab an adapter, but I wanted to follow up with you on the correct rom again. You said earlier that one I tried was Next8HD8G-NXM8000ND_WM and I may have Next8HD8G-NXM8000ND_WMN model/board correct? And I should use same for cwm and unbrick kits?
For Inquiring Minds...Update
Originally posted by shaunmt View PostThat would be my best guess... you can't really go too wrong... the files for one model with brick it and the files for the other model should fix it... one way or the other you should be able to get it working...
ShaunMT
Because knowledge is power, I have been reading the conversation between you and Sumphlet.
It appears we have the same issues but complete opposite. Should I attempt his method of burning the WMN kit then copying the WM kit over it? I'm switching gears and working on a Samsung Admire, a LG Spirit 4G and a Samsung Attend, but I will be around all day today.
Thanks for your time and your ideas Shaun, they are greatly appreciated and shall be rewarded!
Originally posted by ATLien View Postok after I commandeered a sd adapter I tried the WMN unbrick kit... nothing happens. No backlight, no power. So plan B fell into place thus began the burning of the WM unbrick kit and my screen turned on, but it didn't boot to recovery, just stayed blank but I could tell the backlight was on and I could see the charger light again.
ShaunMTLast edited by shaunmt; 04-26-2014, 22:38.Freaktab Rom Developer
Shaun,
I have a newer model, purchased about 2 months ago. I hosed it up originally, by rooting with the wrong files. It would get to the spinning circle screen then freeze up.
Last night, i tried your WMN SD card unbrick kit and your modded stock ROM. Fired right up. Got your new boot screen, both of them. Perfect. It was snappy and i began playing with it. Decided to reboot afterwards to test. I noticed upon reboot, it was a clean ROM again. Nothing I did was saved. So i went through and hooked up wifi, disabled some apps, etc...Rebooted again. Same thing happened. Did it a forth time, and now it is 100% dead. Wont boot at all. Nothing but a black screen. I get the power light when charging, thats it.
Any ideas? why did it get hosed?
thanks
Rick
There are currently 2145 users online. 3 members and 2142 guests.
