im very lost now ... any idea ?
Mk908 v5 (netxeon) cant boot in flash mode ...
i just receive my Mk908 v5 and when i connect otg to pc usb, it power up and boot, but not detected on windows, even if push the reset button then connect OTG to pc, no windows Bong and the device boot normally ...
im very lost now ... any idea ?Tags: None
Is this your device?
China-1 Stock | Buy Tronsmart MK908 Rk3188T Quad Core 1.4GHz Google Android 4.2 Mini PC TV Box Dongle HDMI HDD Player 2G/8G Bluetooth Dual Wifi Antenna Black online at unbeatable prices. ✓Free Shipping ✓Limited Time Sale ✓Local Warehouses.
Loader mode means your device is ready for flashing a ROM. Does your stick has any button or reset hole or any description to flash a firmware?
JDfense
ok i found how ...
on setting, i found 'device' then USB then connect to Pc ... i clic it and finally found the MK908 on device manager in win7
i did not have to install driver, since i allready flahs my Pipo U8 ....
i flashed finless 1.7 without any trouble, but the reset boutton still not working for entering into flash mode, no big deal but strange
Originally posted by JDfense View PostFine. As long you can boot your mk908 complete, you can switch your TV-Stick into loader, but if not... you will need the reset button. Maybe you can use the reset button for sure, when your stick is open.
Anyway, have fun with your mk908.:-.)
JDfense --->I8160
maybe the button is dead, i will try to check with my tester ...
When the button reset your device, it works fine.
Try holding the button while you plug your stick over otg usb to your pc or plug your stick over otg to pc at first. Then press button for a few seconds.
One of those two methods should bring your stick into the loader mode.
JDfense ----> Nexus 7 ~ 2013
There are currently 2389 users online. 6 members and 2383 guests.
