Custom EKB311B, MT7601U Wifi ROM
    Please Help
    established Dmesg, it pressed the point Unistal appeared window Reboting, he was not included,and hang with a black screen.
    wanted to pereustanovit in RKBatchTool--1.7
    25% publishes red line
    Downlad Firware Fail
    Restore Is Done Success Fail 1 0
    What to do nobody knows?
      Originally posted by Shv View Post
      Please Help
      What device do you have?
      Post all the chip names here after opening it.
      Maybe you flashed the wrong firmware to an incorrect device.
        Какие устройства у вас есть?
        Post чип имена здесь после его открытия.
        Может быть, вы мелькнула неправильной прошивки неверное устройство.
        the device is the same as you,All is well with 30 attempts loaded, thanks for the concern, as the case be with firmware something is obtained with the Kit kat?
          User d33 is working on a KitKat kernel with MT7601 wifi, but don't know if the wifi will work.
          User omegamoon is also working on 3.0.101 kernel that will have working MT7601 wifi and Linux support with wifi.
          I will release a new rom for EKB311B later today.
            Hi mo123
            Some things I noticed when testing the HG image
            - IR Remote Key repeat doesn't work
            - Numeric buttons on the remote don't work (Can be fixed by copying stock key layout files)
            - "Autohide system bar" missing
            Will your ROM include all those fixes/tweaks?
              hackadroid;157609]Hi mo123
              Will have to check
              Done
              Done
              Yes
                Will have to check
                Done
                Done
                Yes
                Awesome, thanks
                  mo123,
                  I'm intending to spend some time tonight building a final series of Kit Kat Kernels and will publish some test kernels to see if I can get the MT7601U supported. If you could test them and report back I can possibly iterate through a few options during the evening (UK time). will you be able to test?
                  Donate to Finless
                    Originally posted by d33 View Post
                    mo123,
                    I have the same box and can help out if needed
                      Cool.
                      For my reference tonight:
                      Pin3_PA0
                      Pin3_PC5
                      Donate to Finless
                        Cool.
                        Pin3_PA0
                        Pin3_PC5
                        Not quite at that level yet, thought I just had to flash a kernel and confirm things work
                        Happy to follow instructions after flashing your kernels
                          LOL for MY reference! You just need to flash a KK ROM and then test a few kernels for BT/Wifi function - fear not.
                          Donate to Finless
                            HaHa
                            That I can do
                              Sorry d33, have to postpone till tomorrow
                              Can you send me links to the kernels so long?
                                Anyone subscribed to this thread and wishes to help this evening with testing KK kernel support for MT7601 wifi please can you scoot across to this thread?
                                Donate to Finless
