Anyone playing with one of these? [FVIEW U2]
    What do you mean by switched fro IR remote
    Originally posted by peyoker View Post
    hi peter, try this: unplug power cable for a one minute from tv box side, after a minute you can connect and push power button.
    if you shut down from a IR remote, will need do so.
    Hello, can you please let me know what is te best / exact procedure on how to switch and off the Fview u2 android tv box. Thanks once again for all your help
      i did compressed with RAR5. you have winrar updated?
      i now redownloading for check.
      edit:, i unrar successfully with winrar 5.10
      edit2: i reuploading in .zip, take two or three hours.
      The rar file seems fine.
      I tried with both android tool 1.37 and 2.3
      With 2.3 the firmware failed to flash into the device.
      For 1.37 I tried with earseIDB, however, the tvbox still fixed at "Dinghan Innovation".
      I will try to do more research and find out the problems.
      19
        19
        I read about it and they said that 2.3 does not work properly for flash userdata (or user i dont remember )
        not know more how to help you, maybe someone with more knowledge knows if you have to flash one loader, or other help. i do not know, sorry.
        i think bob (of rom fineless) did a thread to help, perhaps he may help you
        if you succeed, i appreciate it tell me how!
        good luck
        howgh
          Hello peyoker, I tried to do what you instructed me to do but I had no success. Any other ideas of what I must do or what may be wrong with the mentioned Fview U2 android box ?
          I'm afraid its going to make me nervous and I will just break it up into pieces.
            when happend to me, i solved it those.
            if never worked, i think the best thing is you contact with the seller.
            howgh
              I Email the Dinghan Innovation.
              The technician there gave me an offical rom. It works well. My TV box is back to live again.
              百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
              Key:88aj
                Key:88aj
                im glad!
                thank you very much for sharing the rom!
                howgh
                  Hello peyoker, so what you did to solve your problem was to unplug the android box from the mains for 1 minute or more and then you switched it on from the switch with blue LED and then you pressed the power button on the remote?
                  Is that the sequence that you used to switch it back on ?
                  Thanks for all your help and patience.
                    hi peter, maybe me explain wrong.
                    i have this problem when turn off from the remote control.
                    to solve i did this.
                    1 unplug power wire.
                    2 wait a minute.
                    3 plug the power wire.
                    4 now you can push the button on the tvbox, dont touch any button on remote.
                    5 now blue led is on, and automatically boot.
                    if dont work for you, try to boot in flashmode and try to flash rom posted by leoncoolmoon
                    but if you have a rk3188T, i think you cant start in flashboot mode or pc do not recognize it.
                    i do not know the reason.
                    howgh
                      Hi friends, I was able to install CWM Recovery, now you can easily make a backup and recovering, spread apk and video instruction. https://www.youtube.com/watch?v=nWOPFg81TBg
                        works flawlessly, thank you very much
                        howgh
                          Key:88aj
                          Hi leoncoolmoon,
                          the link
                          is no longer available.
                          You can make it available somehow.
                          Thank You.
                            Originally posted by Stefano_it View Post
                            Hi leoncoolmoon,
                            the link
                            Thank You.
                            hi stefano_it, i downloaded when its online and reuploaded here
                            howgh
                              OTG cable
                              Hello everyone. Can someone let me know how the OTG cable should be or from where did you manage to buy it. Any links to sites which show me how I can produce my own OTG cable. When putting the android box to which port are you connecting the OTG cable ? Thanks for all your time and help.
                                Hello, I've never needed OTG cable with this tvbox. standard cable is sufficient.
                                To connect with pc, you need use this port ( i think doesnt work on RK3188T 1.4ghz )
                                howgh
