My situation:
minix neo x7 with stock 007 fw rooted, and cwm recovery installed
My little problem:
To solve my big problem, I thought to try using cwm recovery as a first attempt: I'm not a newbie with android, but I don't know how to use CWM in this device, because I can't move through the menu ... there's no buttons on the minix, except the power button, with which I can just confirm the option selected when I enter the cwm recovery .. that is "reboot system" .. not very usefull
My BIG problem:
suddenly, without an apparent reason, my minix x7 doesn't recognize sdcard space .. so I lost all user data under /sdcard folder: I played with asphalt 8 after lunch, then I powered off the minix ... and after dinner, when I powered on the device, the sdcard wasn't recognized by minix system
I realized that thing when I noted that some apps disappeared on the app-drawer
infact, If I try to explore filesystem with a file browser (I use es file explorer) I receive a message that tell me "sdcard not mounted or not present"
I tried to switch off the minix and disconnected it from all the cables, then I reattached all and powered on the device .. no changes: sdcard not mounted or not present
I have also terminal emulator installed, so I would try to re-mount the sdcard, but ... I really don't know how to discover what block partition is the user space, so I can't write a command line that makes sense ...
I need some help: my first target is to try recovering sdcard
or at least, if it's not possible, I want to try saving the data (mainly /sdcard/Android/data and /sdcard/Android /obb folders and subfolders) on an external memory, and then I think it's a good idea to flash another (better if "custom" and rooted) rom
PLEASE, help .. I don't want to loose all data user before flashing another firmware
thank a lot in advance for any reply
