Use it as a router?
Use it as a router?
I have a T-R42 which has an ethernet input. I was thinning to ditch the router and use this as a hotspot router. Have anyone tried to use their Android tv stick as a router? I know I will miss the customisation a router gives, like firewall and many other. But I would like to know if it is a dumb to use it as a basic router or is it even safe, specially while there is a micro sd card inside with private files. On the other hand, I am thinking if it wasn't safe, everyone would already have their files stollen from their phones.Tags: None
Yes.. i did -on my tvbox
Root the unit
Installed a firewall
Dns changed to 'adbarricuda' (just google it)
Installed : 'adaway' to block even more stuff
--this works on 'droidtv x1"
Also tried (failed)
Install openvpn connect... then share its connection to wifi user
My main goal was to no-longer see any ads on my 'tabled and ereader' So quicker browsing
-like freaktabs logo.. i could not browse the site on my e-reader (made a rule block png image)
--and now i can browse forums again
Androidsticks are not really usable as router.. (as must dont have lan access or good wifi or many usb ports)
Anyway.. goodluck
There are currently 1516 users online. 1 members and 1515 guests.
