Android 4.4 on rk3066
    Originally posted by mite_jan View Post
    i was not flashing the bootloader thats why the roms didnt work
    after flashing it i was able to boot them
    no wifi on the UG802 , and the cx 803 rom
    if anyone has ideas how to make the wifi work share it
    You need the correct GPIO dump with the correct wifi pins from a JB rom.
    The GPIO Dump app binary is in the kernel section of the forum.
    Then you have to compile a new kernel with that pin numbers.
    Unfortunately I don't know which kernel source to use.
    Hopefully with the RK3288 kernel sources being released next week, someone can use that.
      i am not so experienced to do the compiling job
      but i would gladly try some test kernels if someone would compile
      without a wifi kitkat is useless for me so going back to jellybean
        Originally posted by linedead View Post
        I saw this video on youtube and I was wondering if anyone has more information about the upgrade of our rk3066 to android 4.4 ¿?
        Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
        If anyone has more info, please share with us
        The android 4.4 can re energizing our rk3066 !!!
        Try this,suits for RK3066 MTK device(MK809II,UG007II,J21),we have tested.
        www.hindotech.com
        contact: 0086-755-89344684
        email: [email protected]
        Skype: luke.guo1
          http://www.hindotech.com/download/sh...?lang=en&id=28
          Is it 1080p firmware?
          ~Gopichand Pai
            Right..there is 1080p setting in the system,not sure if it is the correct you are after
            www.hindotech.com
            Skype: luke.guo1
              gopichand you've already tried that firmware, you've posted to the thread discussing it - http://www.freaktab.com/showthread.p...Fully-Working)
              The firmware's stock kernel is 1080p outputting the UI at 720p via an overlay. Remove the overlay code in build.prop and you get full blown 1080p for both UI and video content the same; no different than any other 'full HD' 1080p kernel.
                Thanks Since I used a different link to download the firmware in that other thread, I was not aware if both are same.
                ~Gopichand Pai
                  Minix X5mini
                  Hi all,
                  I was wondering if it's possible you kindly consider to compile also for X5mini a 4.4 rom...that would be amazing.
                  Just if helps, I attach the best rom in 4.2.2 I know, which is already rooted and has 1080p kernel version, to please consider as a base to work in.
                  If it's better the official one, which is non rooted, I attach it also:
                  Please let me know if it's tecnically possible.
                  I would really appreciate your collaboration.
                  Kind regards
                    Please share the link
                    Originally posted by neomode View Post
                    I have found a Android 4.4 Version for a Pipo S1 Tablet. It has a RK3066 CPU.
                    For wich Device you want it?
                    Neomode
                    Hi neomode,
                    can you share the link for that rom?
                    RP
                      COMPLIMENTISSIMI per questa app, è fantastica! Io ho una rom fatta da Cis80, una ottima ics 4.0.4 con update me. C'è un piccolo problema: il playstore mi indica "aggiornamento", ma quando vado per aggiornare si blocca l'installazione dando errore, forse perché l'app è stata inserita fra le app di sistema. E' un problema mio o capita ad altri? come posso risolvere?
                      http://www.comprarbaratosmoviles.com/star-z2-comprar-android-4-2-mtk6592-octa-core-venta-barata
                        Have make an Android 4.4 for the X5 mini.
                        Look in this Section.
                        Neomode
                        Gesendet von meinem HUAWEI P7-L10
                          I'll create rk3066 kernels for kitkat ROMS and post in a separate thread. Obviously you will need supporting KK ROMs to test with and so this will be for the really experimental and technically competent owners only.
                          Donate to Finless
                            For Pipo U1 Pro?
                            Uhm. Hi. I just want to ask if my Pipo U1 Pro has any chance to get upgraded to kitkat. I checked tho, it has only 3.0.8+ kernel. Well, is it upgradeable? Thanks.
                              I have a Kit Kat Version for the Probox 2 a RK3066 Device. I must say it runs very well.
                              Neomode
                              I have flashed firmware U2.442.000.11.140327
                              on my probox2. wifi and bluetooth isnt working
                              is there a solution for it!
                                thanks for info
