CS968 board version 3&4 with MTK wifi NEW ROOTED 20140313 ROM (My first one)
Thank you for this ROM, works great!
Did you any 4.4.2 Kitkat for CS 968 with MTK5931 (perhaps rooted) ?
Quote Originally Posted by pincer View Post
I've installed your ROM, so far so good (smooth), i did change the resolution using terminal emulator.
Hope you can do too for 4.4 ROM..,
Thanks.
If you can link me to an MTK wifi wirking kitkat, i can do it!
Thanks for great job! My Box have AP6210 Wifi (CS board version 4.0).Naturally Wi-Fi not work.Are you have kernel with AP6210 support with OC CPU, GPU and RAM?
Does your CS968 have the name HTC_T018 20131216 V4 printed on the board inside? Do you see any sudden screen blackouts after all is working?
I am struggling with this issue and is not solved with any ROM I have tried.
Yes it is - CS968 HTC_T018 20131216 V4 main pcb
No , I'm not see any sudden screen blackouts. May be this is a hardware problem in VPU , not a firmware problem. Try to change power supply.
I tried your rom but wasn't able to end the boot phase. At first, it keept on showing 4 penguins and rebooted, starting all over again. Then I pressed the reset button for about 5 seconds and it showed breefly the 4 penguins, then the android robot for about 1 minute and reboot, starting all over again.
I think it's related to my tv box as I flashed the stock firmware and the same happened. Could you build a version of your rom with usb debug enabled by default so that I could use adb logcat to see what's going on ? You can PM the link.
Thanks in advance.
EDIT:
dracosc22679, no need to create a new build with usb debug. I managed to boot the tv box. I don't know why but it only boots if I connect it with a PC (or other source of powered usb) in the OTG port. Does anyone know why ?
Which combination of ROM and kernel are you using? and what HDMI setting are you using e.g. 1080p @50 Hz?
Whats the number (one below 94V-0ML1) on your board? I think its the serial #.
Yes I definately don't have that problem. I am using the rom from this thread - PM dracosc22679 if you don't have it. No other kernels or anything.
I have the same number on my board
I have used it at 1080p 60 and 50 and 720p 60 and 50 and not seen any problems yet.
My board has the mediatek chipset.
I would reblow the rom and try another HDMI cable if you haven't done already
in the lines down under is a link to an official kitkat 4.4.2 Rom for the boxes with Mtk chipset.
That gives >dracosc22679< the possibility to cook the next good rom for us...
The first start of the rom took a while but then bluetooth and wifi was working.
Hope that info was helpfull
CS968 MTK KITKAT ROM 4.4 - Finally
Here's the link, but I don't know which board version, still download it..,
Cheers
here's some noted changes,
- it's stock rom so not rooted,
- kernel is 720p
- beyond xbmc is pre-installed
- many 3rd apps
- free internal memory is 1GB now, (4.2.2 is 1,9GB)
- nand flash (internal sdcard) 5,3 GB now, (in 4.2.2 is 3.9GB)
- HDMI is by default set to 1080p 60Hz
- "SMART BOX" boot animation
- Device known as CS968M,
to root it you need kingoapp please follow tech1 and its people who help write the procedures in his threadhere
my device is cs968 - htc_t018 v.3 board 201311?? (forgot the date), MT5931 wifi and MT6622 Bluetooth.
main: I try two different SD cards (new one and from my smartphone) and in both cases "Damage Device" error apeared. Formatting not solve the issue. secondary: I try login into Recovery Mode using "Quick Boot" app, but after robot with spinning hexaeder logo TV box login into Normal Mode.
