NEW - MK908-II - Finless 1.6 ROM
Originally posted by dubazar View Post
Merci
Originally posted by dubazar View PostTu vas devoir identifier le CPU de ton dongle Android rk3188 T ou pas et utiliser le bon kernel dont l'auteur se prenomme d33.
You have to identify CPU model and choose the right d33's kernel.
Sorry this is the right topic
www.freaktab.com/showthread.php?9390-NEW-Finless-ROM-2-0-KitKat-4-4-2-for-MK908-II-BETA
Envoyé de mon MI 3W en utilisant Tapatalk
comment sécuriser l'appareil avec un schéma ou un mot de passe sachant que dans les paramètres de sécurité l'option n'apparait pas
It has a few fixes that the MK908II/AP6210 specific ROM doesn't have. Just have to grab the correct kernel for the MK908II which can be found here:
Hi, I try this rom on my brand new mk908ii, and its realy good, after updating also my Logitech C525 webcam works fine. Unfortunately I have problem with OC kernels. No matters which I use, the stick boot normaly, but freeze after a while and restart it self. Any suggestions for this issue? I use 2A power supply and the temperature is normal so its not overheated.
There are currently 5698 users online. 1 members and 5697 guests.
