[ROM Download] Official Android 4.4 KitKat Firmware For RK3188T TV BOX and TV Sticks
Here's a DMESG from jellybean official rom for a928. Kitkat won't work as I can't get root or usb mass storage to work on it.
I sent my MK908II back amazon
buyer beware these new tronsmart sticks are utter garbage
planing on ordering a neo x7 to mess with
to anybody looking to buy a tronsmart device just don't ... buy something better and then you won't have a migraine afterwardcurrent devices(rockchip sucks)
Hardkernel ODROID C1 running android kitkat
Hardkernel ODROID XU3-L Running Linux/openelec (primary media server)
rPi model B+ running nothing ... bricked
MK908II have artefacts
Hi all.
Guys, please, tell me what me do with my MK908II? I have problem - artefacts on screen! This problem only in Android 4.4 with kernel 4042-4049.
Just Android 4.4 - don't have artefacts, but have lags, when i see movies (30Gb), with kernel 4049 don't have lags, but have artefacts!
Give me advice plz!
Re: [ROM Download] Official Android 4.4 KitKat Firmware For RK3188T TV BOX and TV Sticks
Give me advice plz!
i understand you very well! But i hope in genius D33 and Finless)
Apologies for the flash, it was hard to get a pic it went away after a second or two of movement. There were blocks of black over video too. Return it and try something else.
Sent from my mobile device. Please excuse any typos.
Originally posted by noderat View PostDoes it look like this? If so I returned mine as I could not get it fixed. Other models do not have this issue.
not exactly.
[IMG][/IMG]
On this pic artefacts. And this black square disappears when i don't use mouse more then 1-2 min
But when i look films - black square don't disappears.
you show pic with not main problem) i have this bug too, when i open settings)) but when i look films i don't see this problem.
Originally posted by chevron4ik View Postnot exactly.
[IMG][/IMG]
Originally posted by noderat View PostYeah that's part of what I had too, I couldn't ever get it to stop. Ended up switching to a a928 and now a Amlogic s802 device.
Then i again repeated step by step my actions and not have affects =(
Thenks for help noderat)
Originally posted by chevron4ik View Postyesterday i set firmware 4.4 from first page - and launched it without kernel. Dont have any problems. Then i loaded kernel 4049. And don't have artefacts too! But, when i set root - artefacts come in sight.
Your screen artefacts can be caused by shortage of power from your stock power supply adapter.
Firmware(with kernel included) from first page has lower power consumption due to the lower CPU/GPU/DDR speed adjustment.
d33's kernels require a little bit more power because they have higher clocks.
Just try to use another PS(at least 5V/3A) and I can bet your artefacts go away(my bet is 75% against somebody's 25%).
CS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
I thought about adapter (i have a stock adapter China), but did not believe it.
One of these days I'll buy a new adapter and write about results!
Thanks for help! =)
Originally posted by Ploggy View PostForgive my noobness but is it true the RK3188T can now be unlocked? I have an MK908 v5 but seems to be locked at 1.4. I would like to have it overclocked to 1.6 if possible but not sure which kernal to install. I'm currently on finless 1.8.
A lot of people here and me too have this crappy T chips inside.
Thanks to d33's kernels and KitKat you can be much more happy with your device.
If you are really interested, try to spend your definite time for reading this whole thread and in addition these two
I hope you'll find good alternative.
I have my T-based box(not of your model stick, it doesn't matter) runing 1080p cpu1704/gpu798/ddr800 and it plays all kind and sizes of movies great.Last edited by digger; 15 April 2014, 21:44.CS918II/16GB(HTC-031-V1.0 board)
I originally bought my stick for Movies/Emulation and while I'm happy with the Movie part I'm finding Emulators like Retroarch run quite sluggish on my stick.
Btw are you using any added cooling mods with your current setup? I dont want to go overboard with the overclocking settings, just enough to get Retroarch running as it should
Thanks again.
Originally posted by Ploggy View PostThanks mate for the advice, I have to admit I broke the cardinal rule and didn't read this entire thread through but I skim it and saw D33 post link's in a few of his posts on here but wasn't sure if they fit my particular Android stick and didn't want to brick or something :P
Thanks again.
Originally posted by noderat View PostYou won't need cooling mods unless you're doing some extreme overclock
Also I downloaded your "AP6210 (fixed)" Kernal from here:
would it just be a matter of replacing my current Kernal with your one? I'm currently on finless 1.8 which isnt KK if I remember right
Thanks.
Originally posted by Ploggy View PostWhat would you say is the non cooling mod limit? like I said I dont want to go ott just enough to get Retroarch Running fluidly
Thanks.
There are currently 1964 users online. 2 members and 1962 guests.
