New Ugoos 3D launcher UT2
Update
3D lancher seems to look and work good.Not sure if any thing has changed with the firmware,but I seem to be getting better audio output through my amp. I was chatting with James (sales manager) @ Ugoos.net and he said ut1 should be getting 4.4 and the new 3d lancher soon,wih the others to follow.
Originally posted by flhthemi View PostOK, help a noob out here. This 3D launcher version is still JB? Did they just change the launcher? I installed Apex on mine.. . Seems to be fine so far.
If your looking for Android 4.4 KitKat firmware for Ugoos UT2 720p/1080p,head over here.
http://allminipc.com/forum/viewtopic.php?f=3&t=1184FLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
Originally posted by flhthemi View PostIs that stock or a custom blend?
Comes with the Ugoos launcher. It seems to run faster than the original.
Also the remote works the same. You may want to try gotham RC1 on it, seems to be working good.
I'm using the one Karel compiled with libmedia passthrough hack, Post 1708 on this thread.
One more thing, I had to turn off passthrough in xbmc, all static on my reciever.
all is good now and getting full surround sound.
Originally posted by wayner View PostAcording to Eugene in sales @ Ugoos.net It is considered Stock.
1 Analog
2 Optical/Coax/SPDIF
No HDMI choice....I guess the "Coax" is supposed to be HDMI...???
Anyway it sure doesn't pass it all I get is static or noise. MX Player, with the custom codec does pass it. NONE of these will pass it even with custom codecs installed. I even compiled the Neon codec for BS Player and no joy.
Vplayer
Dice Player
BS PlayerFLHT = Harley
Originally posted by wayner View PostIn the settings in sound manger did you set it to passthrough, the bottom choice?
Leave it in analog if you are using HDMI, then turn off passthrough in XBMC.
Let me know if this helps, Ill take another look at my setup when I get a chance.
Android set to passthrough HDMI
BXBMC set to analog no passthrough available in analog
No noise no 5.1 either but Gotham is comming
Any big advantage to UT2 being on the stock KK?FLHT = Harley
Did you try this XBMC?
http://www.freaktab.com/showthread.p...-3-4%29/page86
Out of every thing I tryed KK and this XBMC are the only combination that plays 1080p perfect in XBMC.
With sound working as well.
EDIT: Took the plunge and installed the 1080 KK rom. Wasn't thinking and now I no longer have root access. Wonder if there's a way to root this??Last edited by flhthemi; 01 May 2014, 01:26.FLHT = Harley
There are currently 1536 users online. 2 members and 1534 guests.
