Neomode Custom Rom UGOOS UM2 Version 1.0 Android 4.4.2 FullHD
    Hello UM2 Owner´s,
    It has taken a while, but now it is here. The first Custom Rom for the UM2.
    First, I Wanne say thanks to Argos for Sponsoring me one Device.
    What you get?
    A Full Android 4.4.2 with Custom Kernel from d33. Thanks for this.
    I had also had some OC Kernels if someone wants to try.
    What Works:
    -Bluetooth
    -Wifi
    -USB Ports
    What not Works:
    I have no Remote Control to Test please Test it.
    Rom Features:
    Rooted
    Init.d Support
    Added some Modules for External Sound and Lan Adapter
    Software included:
    Reboot App
    No Frills CPU Control
    FX File Explore
    MultiLing Keyboard (Please set it as default Keyboard if not you have only Voice Input)
    Google Home Launcher
    Terminal Emulator
    Kernel:
    Custom Kernel from d33 with True FullHD.
    Download:
    Upload Running please wait one Hour
    Regards
    Neomode
    What is the wifi module used on kernel?.. It will work on minix neo x7?..
      AW: Neomode Custom Rom UGOOS UM2 Version 1.0 Android 4.4.2 FullHD
      No it will not work. Different Wi-Fi and not supported with this Rom.
      Sorry
      Neomode
        Sorry
        Neomode
        Works brilliant neomode! Great work and thank you for giving us a working rom for this device.
        Wifis perfect and the video playback with beyond xbmc is awesome.
        So please with this.
        With regards to the remote. It seems to work to a point. the arrow keys and return keys work but i cant seem to get function of the mouse to work on the remote.
        Thanks again
        Steven
          Thanks again
          Steven
          @ shenery still haven't have time to flash it, because I'm fixing my Laptop , but what Kernel are u using with this rom? Thanks
          -Chromecast with Google TV
          - Android Q Android 10
            I think he used my custom kernel.
            Because this is the only that works
            Take it and your device will fly.
            Neomode
              Neomode
              Lol
                hey,
                i've just installed the new rom. have to say - i am quiet disappointed.
                my first impressions so far:
                - keyboard. it was quiet a challange to switch to keyboard instead of voice input. cost me some nervs to be honest.
                - with full hd screen mode i've the same problem with my sony tv like any other rom so far. the screen black outs i've to admin are only every 5-10 seconds. not every 2-3 seconds like the last one. but there is no 1024p mode which solve my problem the last time. now i've switched to 720p and its working fine. but my hope was to get full hd ...
                - wlan is also not too good. had already 20Mbits at the exact same position. now i have 8-10Mbits
                - the ok button on the remote is definitly not working. which makes it hard to use the remote at all.
                now i am thinking about what to do. just want to use the stick for xbmc in my sleeping room. but with the flaws so far i am not sure if i should install everything and set up the xbmc to learn then i've to switch again ....
                ... what are your impressions?
                regards
                christian
                  Good day!
                  After installing this firmware my UM2 unbootable.
                  Appears on the screen logo UGOOS further loading is not.
                  What could be the problem?
                  Thank you.
                    You must first erase idb than flash the rom.
                    Neomode
                      No cwm-recovery
                      Neomode
                      Hi, why there is no cwm-recovery? This is a must have feature. Thanks
                        Hello UM2 Owner´s,
                        What you get?
                        What Works:
                        -Bluetooth
                        -Wifi
                        -USB Ports
                        What not Works:
                        Rom Features:
                        Rooted
                        Init.d Support
                        Software included:
                        Reboot App
                        FX File Explore
                        Terminal Emulator
                        Kernel:
                        Download:
                        Regards
                        Neomode
                        Noticed a couple of bugs. Netflix has really poor quality now. Does it maybe think its on a smaller screen? Also the rockchip remote i use to control the tv box goes very slow. Its like the cursor is delayed. Everything else works great though
                        Cheers
                        Steven
                          Yes, I do EraseIDB.
                            UM2 does not work at 1600 and above
                            My stick works with this rom, but with a different kernel (1400MHz) .
                            Concluded that my stick does not work as well with other firmware with CPU frequency 1600 and above.
                            Sorry, the question is not on topic.
                              Hello UM2 Owner´s,
                              What you get?
                              What Works:
                              -Bluetooth
                              -Wifi
                              -USB Ports
                              What not Works:
                              Rom Features:
                              Rooted
                              Init.d Support
                              Software included:
                              Reboot App
                              FX File Explore
                              Terminal Emulator
                              Kernel:
                              Download:
                              Regards
                              Neomode
                              Hello,
                              i am using this rom, and d33 4.1 stick kernel on a mk908ii T and its all good, the only problem i have is that screen scale dosen t save after reboots. is any fix for this ? or ..like to edit a file with root explorer or something to fix it? thx in advance
