Neomode Custom Rom UGOOS UM2 Version 1.0 Android 4.4.2 FullHD
    IR buttons
    The remote control does not work properly:
    Button -> maps to:
    Fast forward -> OK
    1/A/a -> Mouse mode
    Menu -> Back
    I am looking for the menu button to show the options for an item (needed to add favorites in XBMC).
    Is there an way to edit these buttons? Kernel or perhaps in XBMC?
      Neomode, could you share the .config you used to compile the kernel and what source you used?
      Thanks!
        Hey .. great work on the rom, its the only 1 that works for me.
        I just have a lil question..
        Is there a way to turn of the USB conect to pc at start?
        The usb port connected is the only one i can use with mu usb hub and got my lan and 3 dongles conected.
        I sometimes forget to turn it of and progamms using one of my usb sticks crashes and reboots the device.
        Keep up the good work
          hello Neomode
          I flashed this firmware - but in fact, I not received true FullHD
          all icons so big, and my tv show as signal is just HD
          what I do not right?
          p.s. before flashing firmware - of course I pressed Erase IDB
          thanks
            btw
            I try flash other kernel from dc33 - (SD version) - and resolution same - 720p
            HD and SD kernels - give same result - just HD resolution
              Good Morning,
              Did you have a Full HD Television?
              Also did you try to Set the Resolution in Settings.
              Please send if you can a logcat of the Device.
              Regards
              Neomode
