Which CX919II ? New type ?
    I've received my CX919II today. It's one of the orange versions with the 2 antenna's. I've read some more on this board and couldn't find my board it seems so i'm a bit unsure which firmware to flash. After opening the case it is an RK3188T and i found the following text on the board:
    CYX_809III_RK3188
    V2_1 20140208
    Here are 2 pics of the pcb:
    and
    (Full size here: https://db.tt/tTKn8ZOa and https://db.tt/zYjpnUHH)
    Anybody an idea which stick this is exactly? Which firmware can i flash without bricking this stick ?
    hi,
    Same hardware, I advise you to do not flash for the moment if you do not want to lose WIFI and BT
    If you have stock firmware or find a compatible firmware, i'm interrested
      Originally posted by kristoma View Post
      hi,
      http://www.freaktab.com/showthread.p...N-with-ESP8089
      I was playing around with this stick yesterday and dumped everything on it. So yes, i've got a complete dump of the stock firmware. Could that be of any use ?
        My seller can not provide it to me so I would be indeed very interested in this dump if you can make it available !!!!
        I'm sure it will also serve the community in the near future until a functional custom rom
          No probs. I will upload it to my dropbox this weekend and share it with you/others. Or I can upload it here if possible. I just have to check if the dump i made don't contain my Google-account data :-)
          I just followed this excellent guide http://www.freaktab.com/showthread.p...ew-RK-2-1-tool
          I'm just uploading the most important dumps without the userdata.img & user.img because that last one alone is almost 8GB. What i can upload is:
          parameter.txt
          backup.img
          boot.img
          cache.img
          kernel.img
          kpanic.img
          misc.img
          recovery.img
          system.img
          Will this work ?
            I'm a noob in flash rom, I have my dongle since 1 Week.
            I do not have enough knowledge to confirm that it will work.
            I would do the test.
            Typically i found in flash tools the following files:
            parameter
            misc.img
            kernel.img
            boot.img
            recovery.img
            system.img
            And a bootloader for a kitkat rom example
            RK3188Loader (L) _V2.13.bin
            Someone can confirm it will work or if it's possible to mix files (this dump kernel with an other rom and bootloader ??)
              this is stock rom
                @gabrago : Thanks to you but sadly, this stock firmware don't boot for me
                @jiepiewie : I'm still interrested by your dump for :
                parameter
                misc.img
                kernel.img
                boot.img
                recovery.img
                system.img
                  please tell me where I can upload
                    android boot log
                    Attached is log of Android boot.
                      comments
                      Relevant lines, according to me:
                      1)[ 0.000000] DDR DEBUG: init success!!! freq=348MHz
                      2)[ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00130000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x 00008000@0x00004000(kernel),0x00008000@0x0000C000( boot),0x000C000@0x00014000(recovery),0x00100000@0x 00020000(backup),0x00040000@0x00120000(cache),0x00 200000@0x00160000(userdata),0x00002000@0x00360000( kpanic),0x00100000@0x00362000(system),-@0x00462000(user) bootver=2013-06-20#1.24 firmware_ver=4.1.1
                      from this line you can see that boot loader version is 1.24
                      3) [ 0.659727] cpufreq: delete arm freq(1608000)
                      4)[ 2.636826] [MT6622] mt_bt_power_init
                      bluetooth
                      5)[ 7.807208] rknand_buffer.c version: 4.38 20121130!
                      nand module is 4.38
                      6)[ 19.487627] Current WiFi chip is ESP8089.
                        Tx for your help, but i think that i can't solve this by myself.
                        I want to try to root and insert wifi module but i don't know if i'm on the good path and i'm lacking of time to watch this.
                        If someone can upload somewhere (dropbox, googledrive, mega ...) a complete backup firmware for this hardware ???
                        for example :
                        parameter
                        misc.img
                        kernel.img
                        boot.img
                        recovery.img
                        system.img
                          upload done
                          Please be sure that your loader is version 1.24,
                          I have put it in the rar file.
                            https://mega.co.nz/#!Nt42HapA!O0LoeC...ncQNJwCYxHMdIs
                            You are my savior!
                            I do the test as soon as I find the time and confirm back here just after.
                              Bad news !
                              Maybe i miss something, but no video signal at boot
                              Your boot.img ans kernel.img have exactly the same size, i do not Know if it is normal ?
                              I'll try again an other day ...
