and follow instructions from the second rom I posted. There are a few people on that thread who have flashed the rom and had good results. :0)
Which CX919II ? New type ?
hello please help
hello look was following your tutorial on how to backup my rom
but with the rom that had me facing many problems wifi did not have nearly scope then tried a custom rom NeoMode but served the wifi or bluetooth so I decided to change the kernel for my backup and tv stick I boot but only showed recovery mode then froze there my problem started loderbin decided for a change I found on the web and install this install 3 Bloo did not know which was eventually names are RK3188Loader (L) _V1.04.bin
2) RK3188Loader (L) _V2.13.bin 3) RK3188Loader (L) _V1.05.bin
the problem I have now is that the pc does not recognize my tv android and does not start only heats but gives no video and no do not recognize any program to install another rom thanks in advance do not know if the problem is the drivers or please help
hello
hello again I already achieved correctable problem, tell them not to spend your time on that, just two more things that are not in kitkat restarts and lots overheats when I watch videos on facebook.
The other thing is that I can not connect a joystick for usb because when I start to play it this reset coupled with the wifi signal is very poor only serves no problems being near the router if anyone knows how to fix these problems and can help me, I'll very grateful, excuse me if I do not write very clear but I'm using the google translator
ADB
Originally posted by adamoz View PostI am having trouble getting ADB going, I have added the device to the adb_usb.ini and tried installing moborobo, but it just wont find the device..
Anyone using adb with the above roms?
Then check if 'connect to PC' is enabled in USB menu under settings.
ADB is only working with the modified ADB binary from Sparky (it's using an exploit).
My advise....try to root your stick with TSSparky (JB ROM), then install ADB via WiFi....works like a charm.
There are currently 1793 users online. 0 members and 1793 guests.
