NEW Upscale CR11S/CS968 2MP/5MP/1080p 3D Plus4K Ultra-HiDef MultiMedia Super ROM AP6210 {Beyond XBMC v3.4) READY
    The NEW Just Released UPSCALE highly enhanced over the current version Ultra HiDef Multi-Media Super ROM is the ONLY difference ... (UPSCALE HIGHLY ENHANCED VIDEO RESOLUTION QUALITY)
    You can the 2MP Version HERE http://www.sendspace.com/file/elamkl
    You can the 5MP Version HERE http://www.sendspace.com/file/y4j2nl
    *The UFC TV app and lots of other new Android TV apps can be found HERE https://plus.google.com/communities/...artnerid=gplp0 ...
    Pay-Per-View LIVE SPORTS EVENTS VIA YOUR ANDROID TV BOX
    UFC TV ON Android TV 4.2/4.3/4.4 Boxes {You Still Have Time To Register And Order The BIG Coming pay-per-view Event}
    ChromeCast/Android TV Has Not Been Upgraded With This App Yet
    {Therefore Side Loading Is Still Required}
    You Can Get The UFC TV App HERE
      Tech1, I already on the previous plust4k hi-def rom, do you think it worth it to upgrade to this version as far as video quality is conern? The reason I ask because I will have to redo my setup again. Thanks.
        I really don't know what to tell you ... I have it set up on one of boxes only .... On my other box, I still have the current ROM build ... If you want slightly better resolution quality, then yes, go for it ...
          FLIPPS HD {HiDef} GIVES YOU MORE SPORTS VIA DIRECT WIFI CASTING FROM YOUR ANDROID SMARTPHONE/TABLET DIRECT TO YOUR ANDROID TV BOX OR CHROMECAST DONGLE ...!
          You can get the Flipps HD {HiDef} app here
          https://play.google.com/store/apps/d...nor.amspremium ... Follow the link above for the free SD version ...!
            Thank you Mr.Tech1
            I'm downloading new rom right now and will flash immediately as soon as I get home
              Originally posted by vodanhdaisu View Post
              Thank you Mr.Tech1
              Enjoy it, you now have the best ROM ever and fastest ROM build for your device with the highest video resolution quality for live streaming video and video playback ...
                LIVE Digital Hives Home Screen App Package FREE$$$, Comes In Different Colors
                Android TV At It's Best (Notice ALL The Top TV Entertainment Apps), Plus Google Games, Vudu Movies, Sports Via ESPN, NFL, NBA, MLS And News CNN, "Beyond XBMC" ... No Other Android TV
                Box Can Give You All This Much TV/Games Entertainment Including Amazon Fire TV.. Full Android TV Rules ..! Another Thing To Notice Is
                The Center Screen News Scroll, It Updates Every 30 Minutes ... If something happens around you or in the world far from you, you want to be in the know (Built Into Latest ROM Build As A Widget) ...
                If you want the free LIVE Digital Hives home screen app package like in the photo above, it comes in different colors too, plus more, get it HERE https://plus.google.com/communities/...artnerid=gplp0 ...
                  Best ROM Build For Streaming Video
                  IMOP, I believe this ROM build is the best, that I have every put together for the CR11S/CS968 AP6210, but very few people are downloading it .... Don't go to sleep on this ROM build, don't let it get by you ...
                  What I love most about this ROM build, it streams SD video very clear and it's fast too ... You can imagine how it streams HD video, truly smooth as silk, crystal clear video resolution quality ...
                    Downloaded twice. File is corrupt!!!!
                    EDIT: I take that back, the file isn't corrupt, the name is to long. I shortened the name, and it unzipped fine!
                      I just wanted to be sure, so I downloaded my ROM builds and I encountered NO Problems unzipping my ROM builds ... I now believe the zip extraction tool, you were using is what was corrupt ...!
                        As I said, the file was not corrupt, the name was to long. After I shortened it, it unzipped fine. I use WinRar.
                        Thanks for the help? I've tried everything to get this box to pass through. Far to many hoops to jump through, and still doesn't work. Going back to my MX box. Works great with a linux stand alone XBMC!
                          Why this ROM build works perfect on my boxes, but it doesn't work perfect on your box, something is wrong here ...!
                          Why I don't have to jump through hoops, but you do, come on man ... I got a ideal what's going down, then we want to blame it on something ... See, I deal with cause and effect ...!
                          What TV box are you using and what do you mean by pass through ...?
                            I have a Amlogic Cortex A9 MX box that is running MX Linux XBMC that runs everything I throw at it. It passes through DTS, and Dolby Digital through HDMI to my DD/DTS receiver without any problems what so ever! I just picked up this CS968 because of the specs, but have had absolutley no success in getting this unit to do the same with any combination of ROMS and XBMC that are available.
                            I play my films from a HDD plugged into my router by way of SMB. This is my main objective! From what I have read, even if I could get the CS968 to pass through DTS/DD, it would have to be by way of using MX player, which doesn't work with SMB, only UPNP, which means no scaper info!
                            If you have the answers, I'm more than happy to hear them! I would love for this box to work the way I want it to.
                            In my opinion, development for this box leaves something to be desired!
                              See I told you so, I knew it, dts/dd works perfect with ALL my ROM builds ... I have no problems with the MXPlayer or Plex with dts/dd ... Never ever had any problems with pass through dts/dd ... True, it will not work with SMB only UPnP, because of the http:// protocol ... Since you were not up front with me, I believe you can figure it all out to work like a charm and believe me it does work like a charm, take care guy ...
