You take care too....
NEW Upscale CR11S/CS968 2MP/5MP/1080p 3D Plus4K Ultra-HiDef MultiMedia Super ROM AP6210 {Beyond XBMC v3.4) READY
Beyond XBMC V3.4 Rules {Hands Down With The Option To Use The MXPlayer For Local Video, Movies Playback}
NEW Channels Addons zip Download Location Below, Please Read The Simple Easy Instructions First ...
If You desire ALL the top addon channels via the Beyond XBMC v3.4, then you will need the NEW XBMC7.9 Updated Channels.zip files ..
You will need to unzip the "XBMC7.9 Updated Channels.zip" on your PC and install "XBMC7.9 Updated Channels folder" to your Android TV box internal SD Card "Download Folder" ...
There you can easy access each addon channel zip files to install them by just tap/click on each addon channel zip file, one at a time to install the channels addon zip file to your Beyond XBMC V3.4 ..
*You want to install the "repository Superrepo.org.all addon zip file" FIRST, located in the "XBMC7.9 Updated Channels folder" immediately after the Beyond XBMC v3.4 open during the first installation by going to SYSTEM> Addonbrower (tab below)> "Install from zip file"> External storage> Download (folder)...
There in the Download folder you will see the "XBMC7.9 Updated Channels folder", tap/click on it and install each addon channel zip one at a time ... Each time you will auto go back to "Install from zip file", just repeat the install process for each addon channel zip file ..
You can get the "XBMC7.9 Updated Channels.zip" from HERE IN THE TOP POST https://plus.google.com/communities/...artnerid=gplp0 ...
You can get the latest Beyond XBMC v3.4 HERE
http://www.freaktab.com/showthread.php?10139-Beyond-XBMC-%28Beta-3%29 ...
Originally posted by Tech1 View Post
The NEW Just Released UPSCALE highly enhanced over the current version Ultra HiDef Multi-Media Super ROM is the ONLY difference ... (UPSCALE HIGHLY ENHANCED VIDEO RESOLUTION QUALITY)
You can the 2MP Version HERE http://www.sendspace.com/file/elamkl
You can the 5MP Version HERE http://www.sendspace.com/file/y4j2nl
*The UFC TV app and lots of other new Android TV apps can be found HERE https://plus.google.com/communities/...artnerid=gplp0 ...
May I know this version is 4.2.2? and compare to the version you post on 28/3/2014, which one is better for play 1080P (MKV/ISO) and audio passthrough by HDMI (if can passthrough DTS HD and DD True HD is perfect)?
The Super Rom For 4.4 and 4.2.2, which one you recommend for 1080P? (internal 1GB rom vs 1.9GB rom)
If I flash your super rom, I need to use terminal emulator to adjust the resolution?
And how can I use MX player to audio passthrough? Just flash your rom and install MX player from google play is OK? any decoder in needed?
Sorry for many questions.
ThanksLast edited by edwardckc; 29 April 2014, 05:44.
Originally posted by Tech1 View PostI recommend you to now use the ROM builds found HERE http://www.freaktab.com/showthread.p...ty-(See-Photos) ... All of your questions will be answered in these ROM builds ...! The MXPlayer requires added codec support ..! I will be doing a special instructional 3 part series on how to correctly set up the MXPlayer tomorrow HERE https://plus.google.com/communities/...artnerid=gplp0
Many thanks for your sharing.
I am going to download and flash tonight.
How To Set Up The MXPlayer Correctly, New Series Just Released
The MXPlayer set up option via the Beyond XBMC v3.4, go HERE
https://plus.google.com/communities/...artnerid=gplp0 and read about how to set up the MXPlayer correctly to help with tuff video files playback, it's a new series, just released as promised ... Also get the FREE$$$ MPEG-2 plugin ...!
You can now get the latest ShowBox and VideoMix Movies Apps HERE https://plus.google.com/communities/...artnerid=gplp0 ...Last edited by Tech1; 01 May 2014, 13:35.
Originally posted by Tech1 View PostThe MXPlayer set up option via the Beyond XBMC v3.4, go HERE
thanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostThanks again for all your hard work. I am trying to follow your instructions on correctly installing MX player. But when I click on the link for the libffmpeg.mx.so codec file} .. it can't find the file. Where can I get this file.
thanks
Instructions:
- Download one of the following codec according to your platform as mentioned in the player
(Go to Settings >> Decoder >> Download Custom Codec. Here the you can find the codec type)- Arm v7-Neon [MD5: 95b0e1cd5cdcf5522a2335d98521741e]
- Arm v7-Tegra2 [MD5: def2bb6af2806190d47b13397b2edf6a]
- Arm v6 VFP [MD5: 3c2049d3dd57c55f50071919c8a16a0e]
- x86-SSE3 [MD5: 0f3b8bff35e17a301f648363babd0868]
- x86-SSE2 [MD5: f115c9bd17bb471207219d65ae9b09b2]
- MIPS [MD5:44c7514df72051496e0c394e599f80ac]
- Arm v6 [MD5:b44a690d375bb94c80f7f89cb7a08c85]
- Arm v5TE [MD5:dbe62bc0affbd415d961145d42122a7c]
- Check the hash values to ensure the file integrity.
- Extract files
- Ensure the file name is libffmpeg.mx.so (It's mandatory to work properly)
- Open MX Player on your device.
- Go to Settings >> Decoder >> Custom Codec
- Navigate into the folder you put on your device. It will list all five library files. Press OK
- MX Player will Automatically restarts
- Check whether the codec is in use or not in Preference
- If you want to play DTS while using HW decoder,
- Then go to Preference >> Decoder
- Enable software audio. By this the Video will be rendered by HW and audio will be rendered by SW+
Originally posted by Tech1 View PostFollow the XDA-Developers link in the series photo # 4 and download # 1 below {Arm v7 Neon} ...
Instructions:
- Extract files
clarkssMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Tech1 View PostThe MXPlayer set p option via the Beyond XBMC v3.4, go HERE
Is I need to install mx player 1.7.25?because just find out 1.7.26 in google play but the web said not compatible.
Many thanks again
Many thanks again
Originally posted by Tech1 View PostYes ...! Please see the NEW MXPlayer Series for complete details and instructions, Just Released HERE https://plus.google.com/communities/...artnerid=gplp0 ...
After I finished all instructions, when I switch the player from XBMC to MX, audio can't passthrough DTS and DD, some steps I am missing?
1) install MPEG-2 Plugin Codec.apk that got from your link and open once
2) Install MX player 1.7.25 (last version)
3) Install decoder (Arm v7 Neon) from google play (I check the version is 1.7.25)
4) Open MX player, select player->screen, setting like your #1
5) Download Arm v7 neon.zip and get libffmpeg.mx.so and copy to internal storage 6) select decoder->custom, select libffmpeg.mx.so from internal storage
7) MX player auto reopen
8) Back to XBMC, select the movie file, when it play, audio passthrough is FINE (my amp show DTS or D), but when I click C, select MX (Local player), switch to MX player, the audio back to PCM.......
Please advise.
Thank you so much
There are currently 6854 users online. 0 members and 6854 guests.
