EZ root update ZIP for s802 (all) "Stock ROM" ROMs
That would have nothing to do with using this ZIP.
sorry i did this all wrong and got it working is there anything else i need to do for this tv box i had the s82 put the fw from transmart vega elite did this root patch and have xbmc ... still having some problems with playstore apps and wifi in xbmc is not great
Sent from my VEGA S89 using Tapatalk
Rooting Tronsmart
Hi
Whilst trying to root a Tronsmart S89 as per Finless' #1post the wheels come off as the remote stops working.
Once I select the zip file and then "update" the android (recovery?) screen appears which requires the use of volume up/down and power button to make selections from the menu once the unit has rebooted. There are no hardware buttons on the unit other than power so how do I select "apply update from EXT"?
Second, use a usb mouse or keyboard
Originally posted by chris613 View PostHas anyone tried this on the S89-H yet? from a quick look at the .zip I would expect it to work just fine, but thought I'd ask if anyone can confirm.
ok so i will answer my own question
i can confirm this method does work and it does root the Amlogic M8 quad core.
Now if i could just get direction on how to root the firmware, so i don't have to use this method to root every box i load.
Originally posted by supersonic835 View PostHi will these easy root method work for the Amlogic M8 quad core?
i'm looking for a way to root it, ty
Originally posted by supersonic835 View PostHi Finless will these two firmwares work on my Amlogic M8 quad core?
Nodrat spends a lot of time putting this together and it answer these basic questions.
There are currently 2844 users online. 1 members and 2843 guests.
