EZ root update ZIP for s802 (all) "Stock ROM" ROMs
Originally posted by dimarik83 View Post
Originally posted by Lokie View PostMmm interesting question. I did notice that multitasking is not enabled in the kernel network stack so i suspect that this may be a prob. If it does not work then it could be easily fixed with a kernel update. I will have to look at the aml ethernet driver as well (if the ethernet ip supports multitasking). The ethernet hardware not supporting multitasking may throw in a spanner in the wheels.
How to test this? Anything in mind?
Originally posted by Lokie View PostOk driver & HW supports multitasking so there should be no probs with IPTV multicast support in principle. If it does not work then it should be an easy fix.
Hi Lokie, do you now have a kernel source you can play with ? if so I would very much appreciate a kernel that was not defaulted to 1080p but rather 720p !! is that do-able ?
Originally posted by Ice_Coffee View PostHi Lokie, do you now have a kernel source you can play with ? if so I would very much appreciate a kernel that was not defaulted to 1080p but rather 720p !! is that do-able ?
Kernel source is on its way. Sdk is opened up but there is probs with hosting. Should be sorted in next few days.
Originally posted by Lokie View PostYes can do that. Its defaulted to 1080p at this stage. I think finless 1.5 is defaulted to 720p? Saw somebody complaing about it. Either way, yes it can be done easily.
cool thanks, I don't think finless 1.5 is really defaulted to 720p not in my experience.
It's not reading your SDcard.
Make sure SD is freshly formatted as FAT32 not NTFS.
Originally posted by manu81 View PostYes use FAT32. I will try again format and tell you
Enviado desde mi LG-D806 mediante Tapatalk
Originally posted by Lokie View PostBTW, Ihad a similar problem. On a serial console I saw recovery complain about the sdcard being corrupted (not cleanly ejected). Use windows to properly eject the SDcard and try again
ALWAYS right click on the sdcard disk icon and select eject. Wait till windows says it is safe to remove.
It should work... It's a pretty generic to KK.
Other question:
Is there any possibility to reduce shut down time of power button from 10 sec to ca. 4 sec ?? It's a hard job to hold the button down for such a long time
thanxAinol Aurora II (CyanogenMod 10.1)
Ainol Flame NP 20130916 (CyanogenMod 11 (4.4.4))
Lenovo Yoga 8
Geniatech ATV1200 (UBoot 20130805; MyGica Build 20130927; XBMC Gotham 13.1 RC1)
Tronsmart Vega Standard (Stock 108K4; xbmc-13.2-Gotham-4K-video-2160P)
Originally posted by Finless View PostYep, you have about a 50/50 chance of corrupting a Fat32 SD card if you just pull it out of your PC!
Thanks guys
There are currently 987 users online. 0 members and 987 guests.
