can i install linux on a CS918 quas core Andorid
Originally posted by aceone View PostI believe it runs XBMC better
Originally posted by aceone View Postcan i install linux on a CS918 quad core Andorid.
Here you can find the Linux section.
Originally posted by mitchell4you View PostHi,
To figure out what firmware/kernel works for your unit
We first need to know.. what version/revision you have.. this is done by opening the unit
And then looking at the pcb/motherboard
As reference for some models
Note.. to open-up the unit
There are screws under need the rubber-pads of your unit
GoodluckRK3288 Devices
- Overview BOX (LINK !)
There are currently 2027 users online. 0 members and 2027 guests.
