Tronsmart vega s89 16g xbmc problem
    Greetings
    Have just got one of these devices and flashed fin rom 1.2 (thanks a million) and installed the accompanying xbmc apk.My problem is that the audio output is set at android audiotrack and wont let me change , the sound plays thru my mele f10 pro remote speaker only! My other problem is the video output is set on windowed on display mode and wont let me change to full screen.So film playback is not full screen. Would really appreciate anyones help here fairly new to this.
    setup is vega connected to lcd by hdmi no other speakers.
    thanks
    Originally posted by saor11 View Post
    Greetings
    thanks
    You won't be able to change that in XBMC. This is an issue with the ROM not having Audio Device Manager so you can't select defaults. Hopefully somebody can reach out to Eric with geek buying and see if they can include that in newer ROM.
    Video output can only be changed if XBMC is given root access. You must allow XBMC root or it's stuck on normal. Try pressing Z afterwards and it should change aspect ratio. Otherwise the \ key switches from windowed to fullscreen. If not clear please post screenshot.
    Only after you've donated to Finless and Neomode are you allowed to donate here.
      Thanks for that z or / did remedy the screen even do he menu did not change.so I am screwed with the audio so!Click image for larger version
ID:	433528Click image for larger version
ID:	433525Click image for larger version
        Try disabling USB audio by removing its support in /system/etc/audio_policy.conf
        Sent from my mobile device. Please excuse any typos.
          Hi tried deleting the USB setting and it gave me a choice of termination just went with middle one it did not save.when I went back into xbmc,it is now English stereo on audio during watching a movie but still only hearing thru remote.plus the movie plays stuttering
            Installed sound about app and all working now. Thanks for all the help
              Re: Tronsmart vega s89 16g xbmc problem
              Which app did you use?
                The apps name was soundabout on the play store.changed a few settings restart box and knew it was working when I heard touch tones for first time.the settings in xbmc still don't change but I have audio and it is clear.so fingers crossed
                  Hello, I have a question regarding this.
                  I put finless 1.6 rom on the box, however the audio output is still set to "android, audiotrack" and won´t let me change it.
                  Same with Video output is still set on "windowed" and won´t let me change it to full screen.
                  With regards to these two settings, it´s just like it was before the rom update.
                  All the files I have tested since the upgrade work fine now, everything is in sync, etc...
                  So my question is, is this "normal" that these settings can´t be changed and is it a problem in any way?
                  Sorry, I am pretty new to android boxes :-)
                  Mark
                    Hi all . I had the same issue with the sound playing through the mele f10 pro speaker only.
                    I did not like the soundabout as it is a paid app. so I removed the usb section from /system/etc/audio_policy.conf and I can report to have the sound back through my HDMI connection.
                    you must have the device rooted to change this file.
                    Thanks noderat !
                      Thanks noderat !
                      it worked but how did you get rid of the static sound coming from the remote speaker I know its low but I would like to switch it off
                      Sent from my NX403A using Tapatalk
                        Never noticed any "static sound". I will check when I get home.
                          It only comes on when you are playing a video on xbmc eg when scrolling thru menus its off .its like the speaker is on sound but none of the actual audio from the TV. Just thinking of battery as well
