UPDATED UPSCALE NEW KitKat 4.4 CR11S/CS968 NEXUS7 Custom ROM Ultra HQ Multi-Media Super ROM
UPDATED AGAIN 5/1/2014 ....!
These ROM builds have been updated again, the {Defective Reboot App has Been Removed}, just install the Quick Boot.apk from the market found here https://play.google.com/store/apps/d...ions.quickboot
ROOT INSTRUCTIONS
A lot of you are having problems with how to SYNC your Android TV box with your PC ... Another easy way to SYNC your Android TV and PC is via "Moborobo" first before running the "Kingo RooT app ... Doing it this way, you will know already, if your Android TV and PC are SYNC before you run the Kingo Root App ...
Please Note: Before doing any of the above, the correct drivers must be installed on your PC ... See post # 1 for the drivers package download, if needed ...
You can get the "Moborobo" app HERE http://www.moborobo.com/products/ ... Please read the easy, instructions first ...
ROOT INSTRUCTIONS:
Please use the simple easy, easy, easy root instructions using the "Kingo Root" method found HERE http://www.kingoapp.com/android-root.htm ... Please install the "Kingo Root" app to your computer, before going any further ...
That has now been fixed (Patched), just use the easy, easy, easy "Kingo ROOT" method, that's found HERE to root your Android TV box ...
If you need drivers for your Windows PC, you can get them out of the ROOT package found HERE http://www.mediafire.com/download/55...CR11s_root.zip ...
1.\ First make sure ALL DRIVERS ARE INSTALLED On Your PC, on your Android TV box {CR11S/CS968} go to Settings> Developer options> in the upper right corner turn "ON" USB debugging, click/tap "OK" and check mark the block "USB debugging", click/tap "OK" ...
2.\ Next connect your Android TV box to your computer via USB ... Go to Settings again and go to USB, check mark the block "Connect to PC", you should hear a sound from your computer ...
3.\ Now run/open the "Kingo Root" App on your computer, once the "Kingo Root" app has sync to your Android TV box, just tap on "Root Again" ... Be patient this may take a few minutes, your Android TV box will auto reboot, you Android TV box is now rooted ...
Please Be Patient, This Thread Is Work In Progress ...!
Description
These ROM builds are basically like my 4.2 ROM builds with High video resolution quality being the main asset, along with fast speed ..
You will find the very same widgets, that were in my 4.2 ROM builds, enjoy ...
Get The 2MP Version HERE http://www.sendspace.com/file/fsbvgs ...
Get The 5MP Version HERE http://www.sendspace.com/file/iqhy2z ...
*1080p Set up Settings:
Using a terminal emulator type: (use at your own risk after setting your TV to 1920 x 1080 x 60) ...
Code:
su ↵
wm size 1920x1080 ↵
wm density 240 ↵
Reboot your Android TV box ...!
Get new Android TV apps and updated info HERE https://plus.google.com/communities/...artnerid=gplp0 ...
You can now get the latest ShowBox and VideoMix Movies Apps HERE https://plus.google.com/communities/...artnerid=gplp0 ...
