UPDATED Again {5/1/2014} UPSCALE 4.4 KitKat CR11S/CS968 {SPOOFED AS A NEXUS 7} HiDef Custom Multi-Media Super ROM AP6210
SYNC Your Android TV Box With Your PC
A lot of you are having problems with how to SYNC your Android TV box with your PC ... Another easy way to SYNC your Android TV and PC is via "Moborobo" first before running the "Kingo RooT app ... Doing it this way, you will know already, if your Android TV and PC are SYNC before you run the Kingo Root App ...
Please Note: Before doing any of the above, the correct drivers must be installed on your PC ... See post # 1 for the drivers package download, if needed ...
You can get the "Moborobo" app HERE http://www.moborobo.com/products/ ... Please read the easy, instructions first ...
Re: UPDATED AGAIN {4/20/2014} UPSCALE KK4.4 CR11S/CS968 NEXUS7 HiDef Custom Multi-Media Super ROM AP6210
Originally posted by vodanhdaisu View PostDear Mr.Tech
If I'm not wrong, this rom is NOT pre-rooted, and I have to root it manually right?
Sent from my Galaxy Nexus using Tapatalk
i finaly root the kit-kat rom using vroot , but i can't use reboot tool, to boot in recovery mode and make a cwm-recovery.
justxbmc v4 crashes and won't load, but beyond xbmc works fine ,but i think it can't passthrough the sound .
can i install libmedia hack manually ?
.. will you make a pre-rooted with LibMedia.so hack built in ?
Originally posted by buried View Posti finaly root the kit-kat rom using vroot , but i can't use reboot tool, to boot in recovery mode and make a cwm-recovery.
NEW Addons Channels zips For "Beyond XBMC v3.4"
Beyond XBMC V3.4 Rules {Hands Down With The Option To Use The MXPlayer For Local Video, Movies Playback}
NEW Channels Addons zip Download Location Below, Please Read The Simple Easy Instructions First ...
If You desire ALL the top addon channels via the Beyond XBMC v3.4, then you will need the NEW XBMC7.9 Updated Channels.zip files ..
You will need to unzip the "XBMC7.9 Updated Channels.zip" on your PC and install "XBMC7.9 Updated Channels folder" to your Android TV box internal SD Card "Download Folder" ...
There you can easy access each addon channel zip files to install them by just tap/click on each addon channel zip file, one at a time to install the channels addon zip file to your Beyond XBMC V3.4 ..
*You want to install the "repository Superrepo.org.all addon zip file" FIRST, located in the "XBMC7.9 Updated Channels folder" immediately after the Beyond XBMC v3.4 open during the first installation by going to SYSTEM> Addonbrower (tab below)> "Install from zip file"> External storage> Download (folder)...
There in the Download folder you will see the "XBMC7.9 Updated Channels folder", tap/click on it and install each addon channel zip one at a time ... Each time you will auto go back to "Install from zip file", just repeat the install process for each addon channel zip file ..
You can get the "XBMC7.9 Updated Channels.zip" from HERE IN THE TOP POST https://plus.google.com/communities/...artnerid=gplp0 ...
You can get the latest Beyond XBMC v3.4 HERE
http://www.freaktab.com/showthread.php?10139-Beyond-XBMC-%28Beta-3%29 ...
How Set Up The MXPlayer Correctly, New Series Just Released
The MXPlayer set up option via the Beyond XBMC v3.4, go HERE
https://plus.google.com/communities/...artnerid=gplp0 and read about how to set up the MXPlayer correctly to help with tuff video files playback, it's a new series, just released as promised ... Also get the FREE$$$ MPEG-2 plugin ...!Last edited by Tech1; 30 April 2014, 11:55.
Update 5/1/2014 Again
These ROM builds have been updated again, the {Defective Reboot App has Been Removed}, just install the Quick Boot.apk from the market found here https://play.google.com/store/apps/d...ions.quickboot
Easy Root instructions are in post # 1 ...! The 2MP and 5MP ROM builds are spoofed as a Nexus 7, enjoy...!
There are currently 2091 users online. 1 members and 2090 guests.
