Thanks in advance.
PMID 702C original firmware
Originally posted by a_elizondo View PostCan someone please post the original firmware, the one on their website is some other version with an ugly boot screen (which actually didn't bother me) until I figured out I cant connect to an adhoc network.
Thanks in advance.
Originally posted by BTrum View PostInteresting that in Settings/About the 702c is identified as a 701i .. which clearly it isn't. Does make me wonder if the ST 701i ST ROM might work with fewer issues than the 702c ROM...(both the stock and upgrade.)
Some games such as games by Gameloft do not load and just says not compatible with your device. Tiki Kart crashes as do Skyvi and some other apps. G sensor does not work for all apps.
I am starting to not like this tablet. I am wondering if it is the firmware or the tablet itself that is not good.
I was hoping this rebranded tablet from china would be better than some of the other rebranded no-name tablets from **** with the same features.
Sorry for the rant but it seems these cheap tablets are a hit or miss.
Originally posted by BTrum View PostNo joy flashing ROM with ST 702c firmware LS never actually started reformat. Just hung. I did pull the tablet apart thinking perhaps I could put screen in 701c. No joy, comes apart easily but much glue used attaching components inside.
Or you are not going into recovery mode correctly. Make sure your usb is unplugged, hold the home button while you plug the USB, then while still holding home press power 3 times quickly and volume up once and let go of home. It should work then.
There are currently 2022 users online. 1 members and 2021 guests.
