That is NO FLASH TOOL needed to flash a complete ROM on the S89!
It has been converted to ZIP format you can update from SDcard.
This is completely STOCK. No root or anything.
You Windows 8.1 folks that cant get drivers install should now be happy!
I kind of hate the flash tool anyway and should really only be used to unbrick!
__________________________________
Download and unzip the file. Instructions are inside in the README.TXT
Here are the download links.
ROM -> Tronsmart S89 Standard - Stock ROM (405 megs)
ROM -> Tronsmart S89 Elite - Stock ROM (405 megs)
Enjoy,
