Anyway its the same as tronsmart vega s89 - 100%.
Tronsmart S89 STOCK ROMs (100k4) in ZIP update format
Originally posted by Lokie View PostBeelink m8 is exactly the same as tronsmart (same pcb serial/date etc (http://www.freaktab.com/showthread.p...547#post170547)). Finless runs on mine (16GB) as we speak.
Finless... Maybe you though he uses the tomato M8 box?
Did you first flash the original stock ROM from Tronsmart before applying the custom ROM?
What you should do is flash finless ontop of your stock beelink m8 (its the same FW as tronsmart (100k4) but different bootup logos etc.), or if you already rooted first flash stock tronsmart and then finless. Make sure that you flash the correct FW (16GB beelink m8 gets tronsmart vega s89 standard (16GB))
Originally posted by Lokie View PostNope - used the quick root method first and then finless directly. Though it works fine for now YOU MUST NOT DO THIS according to finless as the 2 root methods differ and might cause problems later on when scripts get modified.
Thanks for your help and support!
Currently I see two problems:
- Google PlayStore only shows apps at no charge (no paid apps)
- With 1080p the text below the icons is hard to read (the text seems to be cropped)
Originally posted by kurthv View PostThe update to Finless ROM 1.2 went pretty smoothly :-)
hello, first thank for your work.
i have a problem, when i'm in the bootloader for update from the sd card i choose the zip file (the good one i'm used to do that for phone) but after the box tell me it can't mount the sd card and try in read only.
i'm on windows 8.1 so it was my only option for update it.
thank you and sorry for my english
P.S i forgot to say i tried 3 different SD card who work great on 2 phone and computers.Last edited by Skyneon; 27 April 2014, 07:41.
There are currently 3389 users online. 2 members and 3387 guests.
