Unlocked RK3188T kernels for Jelly Bean
    I've been asked several times to build Jelly Bean kernels with the T 'locks' overridden. I've finally got round to doing this.
    Thanks to TOM / RADXA for making public their source code. I have simply added override code and put in the DMESG output to indentify if the SOC is a T or not. Other than that it is exactly the same as RADXA. The .GIT repo I used was dated 31st March.
    Kernels are built for TV Boxes (RK1000 codec, TV out and SPDIF support), they're 1080 res. and 1.6 (CPU), 600 (GPU), 720 (DDR).
    AP6210 / AP6330 / RT8188+VMAC / MK7601 wifi variants v1.02
    [edit]
    v1.01 to remove HDMI sleep
    v1.02 Video DDR removed
    Donate to Finless
    no hdmi output (black screen) with ncr19a_mk809, my tv box pcb is rk3188_box_szy_x6 but with neomode kernel rom works
      Which kernel(s) did you try?
      Donate to Finless
        kernel-jb_AP6210.img v100 and v101
          Interesting both boot cleanly on my TV Box (AndroidTV cx921b)
          Donate to Finless
            Hi d33
            Have you changed the HDMI output to 1080p and IT66121=y in the config for Jellybean?
            If I use the KitKat config file and run menuconfig on the Jellybean source, the above 2 options aren't configured correctly on the Jellybean source.
            Maybe that is why people are getting black screens or no boot.
            But you probably already configured everything correctly.
            I also read somewhere you can substitute the Jellybean drivers/video/rockchip files with those from the KitKat source but don't know it it works, since those hdmi/lcd drivers might be the trouble.
              Hmmm .. there was a problem previously with my KK kernel builds where if I set Video DDR then it wouldn't boot. These had Video DDR.
              v1.02
              Without Video DDR
              Donate to Finless
                could you try the 1.02 kernels?
                Thanks!
                Donate to Finless
                  Absolute legend.
                  Goodbye KK... you will not be missed.
                  Currently Using:
                  2 x Nvidia Shield TV | MiniMX III
                  Retired Devices:
                  MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
                    Just try your kernel kernel-jb_AP6210.img on tronsmart mk908ii (rk3188t), doesn't boot after nand erase and full rom installation (finless 1.6 with 1080 boot).
                    I've got the four penguins.
                    Thanks for the work!
                      D33, going to try the kernels on my Tronsmart NX now. Been waiting for a JB kernel that would boot on it. Hoping this does
                      That NX is for sure different although I don't know what it is!
                        Originally posted by dubazar View Post
                        I suspect you need a more recent ROM but thanks for the feedback. THe ROM I'm using to test with is called "htc_t018_pubilic_ap6210_20140226.img". What's the latest 'stock' tronsmart mk908ii build?
                        Donate to Finless
                          Why is it special? I think you've told me once already so I apologize for needing the repetition
                          [edit: Just seen a picture - That's one 'fugly' device]
                          Donate to Finless
                            [edit]
                            Hey Darrel, nice!!
                            Ethernet does not work on CX-921a rtl8188 with kernel kernel-jb_RT8188-VMAC, stock config for radxa does. Wifi works.
                            Donations are welcome and will be shared with other devs:
                            DONATIONS
                            CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
                              Did you get stock remote working on cx-921b?
                              DONATIONS
