1080 requests 4.2 RK3066
Originally posted by farben View PostPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Please test...will patch rk3066 4.2 kernel to 1080
Can someone test.
https://drive.google.com/file/d/0B3T...it?usp=sharingPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by farben View Postquick guide? enough to open kernel, open csv file, patch file and save?
Work from top down
- open the kernel.img
- open csv file included
- push the patch button
- push the rkcrc button
- then save....it will save to the same directory the original file is in
I was curious to see if there are any dependencies on a system that doesnt have microsoft visual studio installed.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by farben View PostI made patched kernel for 409j version but doesn't work stable and has sometimes wrong display in the middle of the screen, kernel which you made for Shomari works better...
edited
wrong display on 1080p movie in XBMC
send me a link to the original and patched...thank you for testing...Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Code:0315A0E3C80304E55C009FE5;0615A0E3C80304E55C009FE5 0D0540E2BC0304E540409FE540009f;0A0540E2BC0304E540409FE540009f 70002DE90110A0E3056CA0E3BE5CA0;70002DE90110A0E31E6DA0E3BE5CA0 144080E52D6EA0E3DC40A0E3B0C0C0;144080E5386400E3DC40A0E3B0C0C0
Last edited by prahjister; 28 May 2014, 02:56.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View PostCode:0315A0E3C80304E55C009FE5;0615A0E3C80304E55C009FE5 0D0540E2BC0304E540409FE540009f;0A0540E2BC0304E540409FE540009f 70002DE90110A0E3056CA0E3BE5CA0;70002DE90110A0E31E6DA0E3BE5CA0 144080E52D6EA0E3DC40A0E3B0C0C0;144080E5386400E3DC40A0E3B0C0C0
Can you tell me what each of the four patches is doing?
Originally posted by jockyw2001 View PostHi prahjister, I searched for these four byte strings in my MK802IIIS kernel. The last two strings (70002DE90110A0E3056CA0E3BE5CA0 and 144080E52D6EA0E3DC40A0E3B0C0C0) can be found, but the first two not.
Send me the kernel.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Thank you guys for testing this one works on all previos tested kernels. Almost ready for final release i believe.
Code:0100EB28409FE50315A0E3;0100EB28409FE50615A0E3 E57F0340E20D0540E2;E57F0340E20A0540E2 70002DE90110A0E3056CA0E3BE5CA0;70002DE90110A0E31E6DA0E3BE5CA0 144080E52D6EA0E3DC40A0E3B0C0C0;144080E5386400E3DC40A0E3B0C0C0
Hi prahjister,
Many thanks for your work
Your 4 patches work fine. My 802IIIS(B) can now play 1920x1080p videos in native 1080p mode.
Now I have pretty much what I wanted since I bought this RK3066 based cheap mini-pc 1,5 year ago: 1080p movie playback with working HDMI passthrough (AC3/DD5.1/DTS).
PS: your KernelMod.exe is not a 32bit application and doesn't run on my 32-bit XP, I did the patches in a hex editor and manually ran rkcrc.
There are currently 1434 users online. 1 members and 1433 guests.
