I just cant find the way to update firmware,did this still want copy or move the file.
Upgrade instruction:
1.) download the above file to a USB drive or HDD, or to the hub directly if you would like to;
2.) NO need to upzip;
3.) Use the stock Explorer app. or other file explorer app., copy the update.zip package to the "Internal Flash" (root directory) of the hub;
4.) System will automatically detect the package and ask for your update confirmation, reboot the system if the dialogue doesn't pop out;
5.) Just choose Install and let the rests to get done;
6.) Remove the .zip file after the upgrade is done completely;
