Help please
    Is asking me do you want to copy in background?
    foreground or background when I select background it say files coping are complite
    if I do foreground then is say can't copy the same file in path.
    After I select this I ''select background it say files coping are complite''
    I rebotot the X7 and is say you are on latest version.
      Dude Thank you so much I made mistake on update.zip my said on the end update.zip.img that is where mistake was.Im downloading new image.I think I got it now
        Yeah the download will be a .zip file - only rename it.
        You may have unzipped the last file by mistake? The update .zip contains firmware .img
        Glad I could help :-)
        Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
        Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
          Thank you so much!
            Thank you so much!
            All sorted then?
              I'm downloading now I need two more hours,so slow will let you know.
                It is all good ant,I have 010b now problem was firmware some how was corrupted.
                Thanks again so much
                  No problem buddy....
