PMID701i - onscreen volume control disappeared
I have a new 701i. I'm not sure what changed between yesterday and today, but my onscreen volume buttons that are at the bottom of the screen have disappeared. Is there a place in the settings, or something I can do with an app, that will restore this functionality? as it stands I have no way to adjust my volume.Tags: None
Originally posted by diabls View PostI'm not familiar with your tablet, as I figred it would be like mine but mine has volume buttons on the side near the power button.. But was the onscreen volume buttons a widget or was it something on the bottom status/menu bar?
I thought that's what you meant, mine doesn't have them on the menu bar so I'm not sure, I know with mine, it came with a widget to change the volume on screen. (which I removed since mine has hardware volume buttons on the side) I have a Polaroid PTAB7XC from Kohls, which from my understanding it's alot like the one you have.
Originally posted by cactusjack1717 View PostI found an app called audiomanager so now at least I can access volume control. It's just weird that the original buttons went away.
My tablet also keeps booting itself up again as soon as I power it off, but that might merit its own thread.
There are currently 2051 users online. 0 members and 2051 guests.
