M8 ROOTED SW(IPTV 458/ACEMAX M8)
Good Version
Thanks from me too! This seems to be a solid version of the factory rom. So far, everything appears to work well - Ethernet connects with no issues, wi-fi is good and even MX Player's H/W + decoder seems smoother than on other factory releases. Apps requiring root just work, with no further effort.
The supplied Gotham XBMC version (late March) also works smoothly with 1080p streams and the interface has no lag.
Edit: The Play Store sees the M8 as a TV device which restricts apps. Inability to install paid apps may be an issue as well. Perhaps a build.prop edit?Last edited by Zahir; 29 April 2014, 20:11.
How did you update?
I tryed update my m8.
Dont know if i did it correctly.
I copied the files to a sdcard.
then i went in to the update menu and choose the zip file and it started.
but when i check system info i get this.
model number
K200
Build number
KOT49H.20140418 test keys
kernel version
3.10.33
Does your 5GHz work?
//Magnus
Updating Firmware
model number
K200
Build number
kernel version
3.10.33
//Magnus
To flash new firmware use the SD card method, as explained here:
There are two ways to update the firmware for tronsmart vega s89 amlogic s802 quad core tv box: 1) SD Card flash method; 2) USB Burning Tool with windows PC […]
In other words, use a "toothpick" on the hidden reset button, and not the updater tool on your current rom.
This is the method I used, and it worked perfectly.
Originally posted by TMx View Post+1
This Rom is Great Sorted my Wifi issues 6mbps to 33-36mbps!!!
Can some post pictures of the revision screen
JustMeBugs are Sons of Glitches!
JustMe
There are currently 1835 users online. 0 members and 1835 guests.
