It is running ICS with LiquidLimez's special superoneclick root and also LiquidLimez's market fix.
Here's the problem.
I can't keep the device shut down. Yes, it is unplugged. Whenever I use the power icon or the power button, EVEN if I do a hold-down-button force-shutdown, it starts itself back up after a couple of seconds.
So if I want it off, all I can do is sleep it.
Has this happened to any of you? What is it about? How can I fix it?
