Q7 Firmware by lewy20041
    This firmware is based on the latest one for Q7 Box from geekbuying.com.
    Please Test and post your feedback.
    *Changelog*
    v1.0.0
    -based on the latest Q7 firmware
    -rooted
    -spoofed as Galaxy SIII for better playstore compatibility
    -build.prop edits (wifi tweaks, beter movies, jpeg quality, etc)
    -gameloft fix
    -new mouse pointer
    -new bootanimation
    -rearanged buttons on system bar
    -fixed few strings (was "Your tablet will shutdown" now "Your Q7 will shutdown")
    -all bloatware apps removed (check orig apps folder in zip if you need any)
    -all usless shortcats removed from launcher screen
    -firmware odexed to better utilize ram and make it faster
    -libmedia.so pached for Dolby and DTS pastrought in XBMC and other players
    -kernel micro stutter fix
    -cpu clock changed to 1ghz to be the lowest
    -new wallpaper
    -new settings under Settings<Q7
    #Performance
    #Superuser
    #Terminal
    #TV Apps
    #Advanced (Resolution Switch, Reboot Recovery, Reboot Bootloader, Update)
    [Use "Resolution Switch" to change betwean real 720p and real 1080p kernels]
    And many other things i dont remember;p
    Firmware:
    Download
    XBMC (Recomended):
    Download
    (All Donations even small are really appreciated)
    Everything is possible if we work together!
    ApkFreak
    Have just flashed your firmware and everything works great, Thanks a lot, Really appreciate it.
    The only thing i couldn't see was, is there a way to make it boot with the system bar thing hidden? Not really a big deal though.
      cant wait to flash this. thanks
        volume up and down
        the sound level fluctuates during streaming on xbmc, haven't tried local content yet. Everything else so far so good
          Thanks you for a great rom. Got it running on two box's running nice and smooth.
            Installed this for a friend, excellent first ROM!
            Only thing missing is the ability to hide system bar
            Thanks so much
              i will add the ability to hide systembar on next update
              ApkFreak
                Thank you very much!
                I'll test playback and report any issues
                  Thank you for your work! If you can fix the glitch on 1080p it will be perfect!!!
                    Thanks so much
                    Why don't you simply install full screen app from play store? It's beautiful, has auto start and many other options!
                      sound
                      Am I the only one having sound issues?
                        voy a probarla
                          hmm interesting
                          i booted up the first time (took about 10 mins to boot), wifi would not switch on, ethernet did not connect, so I rebooted, would not get back to booted... so does not work at all with CS918 - no idea why...
                          mark
                          _________________________________________
                          Out: USB audio, HDMI
                          In: Logitech K400 keyboards
                            This firmware is only for q7 boxes from geekbuying.com
                            ApkFreak
                              *Changelog*
                              v1.0.0
                              -rooted
                              -gameloft fix
                              -new mouse pointer
                              -new bootanimation
                              -new wallpaper
                              #Performance
                              #Superuser
                              #Terminal
                              #TV Apps
                              Firmware:
                              Download
                              XBMC (Recomended):
                              Download
                              after few restarts with Q7_Firmware_By_lewy20041 the device is ON but there is main screen with X pic on it already 10min ? What should i do now, is it normal ?
