Q7 Firmware by lewy20041
you will be able to edit script to put your ow mac address.Everything is possible if we work together!
Is there anyway you can walk me through how to change permission and how to edit the script. i am new into Android. The mac address which I will put on will remain same all the time. It does not change after the reboot right? Thanks
Originally posted by lewy20041 View Postyou will be able to edit script to put your ow mac address.
I was able to change the file permission and edited script, but when I run the script I get this message
"RTNET LINK answers: Device or resource busy"
Do you know the solution of this problem? Thanks
[QsUOTE=lewy20041;195103]you will be able to edit script to put your ow mac address.[/QUOTE]
Originally posted by EGM92 View Postlewy20041 does this rom have the cpu/ddr lock on rk3188t removed?
What is special about the JustXBMC for Q7 Mod you created (justXBMC_Beyond_Mod_Q7.apk)?
How is it different than stock XBMC?
Has anyone successfully been able to do DTS passthrough over the optical/SPDIF interface?
- What should be the settings?
- Does it matter which XBMC version I am running?
Edit:
I got DTS to work.Last edited by the111; 27 June 2014, 22:47.
bluetooth....
Originally posted by lewy20041 View PostFor noROMs. ere will be no kitkat:"
Bat soon i will relise new justXBMC frimware for this box.
Witch will have tons of new futures.
Lewy. TVM for the work on the roms, nearly all works fine. Is there an easy way to get Bluetooth keyboards working with the 1.0 vers. Mine tethers, just will not function once tethered. The same keyboard works fine with the KK beta that Geekbuying limked, so not a hardware problem. The supplied remote with the Q7 is pants, so really could do with getting bt key/flymouse to work. Would it be possible to take all BT files from KK and replace in your rom ?
Originally posted by euromaltese View PostHow can I install Q7 Firmware to the box when the reset button in the ac port is missing?RK3288 Devices
- Overview BOX (LINK !)
Одг: Q7 Firmware by lewy20041
Does this ROM have larger app storage than stock? Stock has 1gb and I have filled it very quickly with not to many apps. I will like to install some more games for my children (q7 works very well with Bluetooth sixaxis controller) and of course I can't.
If this ROM doesn't have larger app storage (2gb would be enough) does any other have?
Thanks.
You have a point there. I found the recovery button and I put the lewy20041 firmware to the box. Everything went fine but when I connect it to my TV it doesn't turn blue by itself . It only turns red and when I push the power button and it turns blue on the screen appears an X sign with a circle going around it, What did I done wrong?
I was able to change the mac address but now the problem is each time I reboot It gives me different mac address. I also tried to change the file permission of static mac folder and put the static address there but for some reason it does not work. How can I make a script which run each time I reboot my box and give me my fix mac address. Thanks
Originally posted by lewy20041 View Postthere will be script for static mac in init.d folder.
just a permition change and you should be good.
There are currently 1905 users online. 2 members and 1903 guests.
