I brought a T-R42 device. It worked 3 days when i asked the supplier to give me firmware for 1080p.
He gave me boot & kernel file for it and i updated as per instruction with DevTool. After the update, It worked for a day and than started rebooting randomly. Than it stopped booting up completely. I tried flashing new wasser firmware and it booted up once, Then when i went into settings it switched off. Now it just does not boot up. Every time i press the start switch, Blue light comes up and after few seconds it goes off again.
I flashed stock firmware from http://www.freaktab.com/showthread.p...351-V2-0-board using batchtool but no luck. Same situation.
Does anyone know what might be the issue?
